Steve W Posted March 18, 2019 Report Posted March 18, 2019 On 3/17/2019 at 8:33 AM, DonMuncy said: Also very interesting to know. I may have to get me one of those small heat guns. They should work much better in tighter spots. I have the Portasol butane iron(I guess it's now the 75 watt version) with the heat end and deflector. But admittedly after starting this comment I remembered I've not used it on solder sleeves, only regular/environmental heat shrink. I like the iron shape better than the mini-torch shape.
DonMuncy Posted March 18, 2019 Report Posted March 18, 2019 14 minutes ago, Steve W said: I have the Portasol butane iron(I guess it's now the 75 watt version) with the heat end and deflector. But admittedly after starting this comment I remembered I've not used it on solder sleeves, only regular/environmental heat shrink. I like the iron shape better than the mini-torch shape. I wish you guys would stop with the new toys that I really ought to have. 1 1
KB4 Posted May 29, 2019 Author Report Posted May 29, 2019 @larrynimmo this is what I used. Pick up some wire at same time No sync wire exists. There is a pin for the sync wire in Whelen connectors. We used Molex connectors with a cable tie to secure connector lengthwise
