Rotorman,
Are you sure that is a 650 in your pic?
Not sure if that makes a difference to the answer...
The 650 will show the same stuff.
14 hours ago, donkaye said:
I've attached a page from the Manual and highlighted in yellow the map of interest.  Expand your 750 map and you will see an airport by the Metar.
Pages from 190-01007-03_Q.pdf
Donekaye, Thanks for that information. I posted the 750 photo since I could not find a 650 showing the METAR flags. I know they are the same since I have used both products.  I had searched the manual under map symbols but had no luck. I now see that these are listed under weather chapter which is 62 pages.
1 hour ago, rotorman said:
Thanks for this great tip. I never would have thought of that.
My theory is if I can't figure it out by button pushing, it is too complicated. :D
