McMooney Posted October 2, 2018 Report Posted October 2, 2018 (edited) Anyone know the correct replacement comm antennae for a 1974 m20e ? Also what are the chances of getting one of the commant combo antennaes to fit ex. ci2580-200 or ci2480-200. Edited October 2, 2018 by McMooney Quote
MB65E Posted October 2, 2018 Report Posted October 2, 2018 Hi the CI 196 is a common upper com antenna replacement. The CI-122 is a common belly antenna replacement. I believe these two antennas are the best suited available modern comm antennas for our airplanes. i have both. -Matt 1 Quote
jetdriven Posted October 2, 2018 Report Posted October 2, 2018 The BNC connector is offset on the base to clear a stringer. This is why only those two antennae work Quote
McMooney Posted October 3, 2018 Author Report Posted October 3, 2018 darn that's what i thought, was hoping to avoid putting more gps warts on my plane Quote
McMooney Posted October 3, 2018 Author Report Posted October 3, 2018 one other question are you sure it's the ci-196 for a 74e commants site says j and k Quote
Marauder Posted October 3, 2018 Report Posted October 3, 2018 one other question are you sure it's the ci-196 for a 74e commants site says j and k Do you have backward 7 antenna now? If so, the CI-196 is the direct replacement for it. Sent from my iPad using Tapatalk Pro Quote
bradp Posted October 7, 2018 Report Posted October 7, 2018 It might also be beneficial to consider a top and bottom antenna combo. I swear the times when I have to break squealch in a dead spot it’s becauee both antennas are shielded by the wing. Quote
Mooneymite Posted October 7, 2018 Report Posted October 7, 2018 https://www.ebay.com/p/VHF-Com-Antenna-CI-196-From-Mooney-M20j-Fit-M20k/10015340501?iid=253415754835&chn=ps&ul_ref=https%3A%2F%2Frover.ebay.com%2Frover%2F1%2F711-117182-37290-0%2F2%3Fmpre%3Dhttps%253A%252F%252Fwww.ebay.com%252Fp%252FVHF-Com-Antenna-CI-196-From-Mooney-M20j-Fit-M20k%252F10015340501%253Fiid%253D253415754835%2526chn%253Dps%26itemid%3D253415754835%26targetid%3D313776935016%26device%3Dm%26adtype%3Dpla%26googleloc%3D9010892%26poi%3D%26campaignid%3D833559251%26adgroupid%3D39417365901%26rlsatarget%3Dpla-313776935016%26abcId%3D1123856%26merchantid%3D6296724%26pt%3D%26gclid%3DCj0KCQjw3ebdBRC1ARIsAD8U0V71XhKbMD7la1V2LCIkDka0a36hMDhsAFO3x1l9p7nv01a7Ukni_oIaAsW5EALw_wcB%26srcrot%3D711-117182-37290-0%26rvr_id%3D1695158053184%26rvr_ts%3D4f3d8d571660ac1c62c75ff8fff88142 Quote
