Skates97 Posted April 19, 2018 Report Posted April 19, 2018 Whenever I have the cowling off to do something I like looking around just to see if something looks odd. Not that I really know what I am looking for but you just never know what may stick out. Last night I noticed that the maximum RPM adjustment screw has a hole through it for safety wire but no safety wire on it. Should it be wired, and if so what to, just around the arm that it sits in?
kortopates Posted April 19, 2018 Report Posted April 19, 2018 Yes, its missing and using the arm should work. Inspect it over the prop controls full range afterwards to make sure it's ok. 1
Marauder Posted April 19, 2018 Report Posted April 19, 2018 Whenever I have the cowling off to do something I like looking around just to see if something looks odd. Not that I really know what I am looking for but you just never know what may stick out. Last night I noticed that the maximum RPM adjustment screw has a hole through it for safety wire but no safety wire on it. Should it be wired, and if so what to, just around the arm that it sits in? Interestingly I usually take pictures before I do oil changes. Caught my governor in this picture. Sent from my iPad using Tapatalk Pro 1
N201MKTurbo Posted April 19, 2018 Report Posted April 19, 2018 That screw has a jamb nut. It shouldn't require lock wire. It won't hurt anything if you lock wire it. The other screw shown that holds the arm on should be lock wired. 1
0TreeLemur Posted April 20, 2018 Report Posted April 20, 2018 What size screw is that? The one on my O360 needs replacing. Trail and error through my A&P’s used screw collection turns up 0.16” (too large) and 0.12” (too small). I need (just right). Thx. Follow up- I think it is a no. 8 screw but stripped out. Anyone had that problem?
Skates97 Posted April 20, 2018 Author Report Posted April 20, 2018 19 minutes ago, Fred_2O said: What size screw is that? The one on my O360 needs replacing. Trail and error through my A&P’s used screw collection turns up 0.16” (too large) and 0.12” (too small). I need (just right). Thx. I'll be out there tomorrow and get you a size. 1
0TreeLemur Posted April 20, 2018 Report Posted April 20, 2018 I think it is a number 8x32 but mine is stripped. Anyone else seen that?
Skates97 Posted April 22, 2018 Author Report Posted April 22, 2018 On 4/20/2018 at 1:58 PM, Fred_2O said: I think it is a number 8x32 but mine is stripped. Anyone else seen that? It is 8x32 and is just under an inch from top of head to end. 1
carusoam Posted April 22, 2018 Report Posted April 22, 2018 Nice work, Richard! writer mechanical skills pilot businessman What other skills do you have? Best regards, -a- 1
Hank Posted April 22, 2018 Report Posted April 22, 2018 Good photos, Richard. But screw length is measured from below the head. Also, don't push things onto the recessed part of the calipers, the outside is the calibrated zero position (the part of the jaws that touch when reading zero). Nice calipers though. I've just recently converted from vernier to digital myself (despite being near sighted, my closeup visual acuity is waning . . . Getting old isn't easy, but it does beat the alternative.). 8-32 is the important part, length looks about 3/4". Don't forget the nut. 1 1
0TreeLemur Posted April 22, 2018 Report Posted April 22, 2018 Richard, thanks for the info. Too bad it isn't some weird metric size... This means that on my a/c the limit lever the hole is stripped so that a No. 8 screw slips in/out. I spoke with my A&P who said he will tap it so a #10x32 fits.
Rick Junkin Posted April 22, 2018 Report Posted April 22, 2018 43 minutes ago, Fred_2O said: Richard, thanks for the info. Too bad it isn't some weird metric size... This means that on my a/c the limit lever the hole is stripped so that a No. 8 screw slips in/out. I spoke with my A&P who said he will tap it so a #10x32 fits. I used a helicoil in mine with the original screw as an alternative to tapping to the oversize. Cheers, Rick
Skates97 Posted April 22, 2018 Author Report Posted April 22, 2018 2 hours ago, carusoam said: Nice work, Richard! writer mechanical skills pilot businessman What other skills do you have? Best regards, -a- I sing too. Just got finished in a production of The Music Man and was part of the barbershop quartet. 2 hours ago, Hank said: Good photos, Richard. But screw length is measured from below the head. Also, don't push things onto the recessed part of the calipers, the outside is the calibrated zero position (the part of the jaws that touch when reading zero). Nice calipers though. I've just recently converted from vernier to digital myself (despite being near sighted, my closeup visual acuity is waning . . . Getting old isn't easy, but it does beat the alternative.). 8-32 is the important part, length looks about 3/4". Don't forget the nut. Good to know, I thought about that afterwards, but by the time I thought about it I had already put it back in and didn't feel like taking it out again just to get a new picture. I think they were these $19 ones from Lowes, but it looks like you can get the same ones for $16 at Home Depot. https://www.lowes.com/pd/General-Tools-Instruments-3-in-Digital-Caliper/3138565 https://www.homedepot.com/p/General-Tools-3-in-Carbon-Fiber-Digital-Caliper-1433/300383994 1
