I recently sent my 3 blade Hartzell out for inspection and reseal. They statically balanced as part of their service. They suggested I dynamically balance when it got remounted which I just completed. I was completely blown away what a difference this made. I literally can put a glass of water on my dash and there would be no movement. Best $340 I ever spent. Sensenich prop at KLNS (Lancaster) did the work and takes 1-2 hours. Great restaurant next door too.
Great Pirep, Charles...
Got any detail on the IPS, before and after?
I know what an IPA is. Heady Topper is my fav.
Not sure what IPS is. If you’re referring to how much weight he put on, all I can say is he screwed 2 different weights onto the flywheel and validated the results with a 2500 rpm run up. What I was told is dynamic prop balancing should really be referred to as engine, prop and spinner balance. A lot of forces at work. Another small point is if you loose a blade or otherwise get massively imbalanced. The vibration forces could literally shake a motor off the aircraft which would be a very bad day indeed. Probably not recoverable if airborne for obvious reasons.
When I had mine done the pre-balance vibration was .4 ips (inches per second). After the process it was fluctuating between .01 and .02 ips. The improvement was amazing!
Inches per second...  the units that dynamic prop balancing is measured...
Before can be close to one... after can be a really small number...
IPA is pretty good too. :)
9 hours ago, Browncbr1 said:
I found that a nicely balanced prop significantly reduces pilot fatigue.
I would think hopes and barley could do the same
