0TreeLemur Posted February 15, 2018 Report Posted February 15, 2018 When recently replacing the panel in our '67 M20C, one of the (original?) circuit breakers broke. It was a 10A. There was a spare 15A so we used that one temporarily. Can someone recommend a contemporary replacement? It was connected to a bus bar on the bottom, and power out on top. It has a similar look to the Klixon 7277, in that the screw terminals are slanted. But- it just doesn't look right. Suggestions appreciated. The top part of the case broke when my son put a screwdriver on it to loosen the screw. Given the brittle nature of the one that broke, I'm guessing others might be brittle too. Quote
tony Posted February 15, 2018 Report Posted February 15, 2018 When I upgraded my panel, I replaced all my breakers and saved my old ones in a box. If you post a part number and I have what you need, I'll send it to you. Quote
Oscar Avalle Posted February 15, 2018 Report Posted February 15, 2018 Same started happening to me a while ago. My old breakers started to brake... I looked into replacing some of them, but then I discovered that the bus bar was in bad shape too, so I decided to redo the whole breaker panel with new breakers. Quote
Marauder Posted February 16, 2018 Report Posted February 16, 2018 Based on what I am seeing on that new breaker panel, it looks like you have room for new avionics. What’s next? Sent from my iPad using Tapatalk Pro Quote
carusoam Posted February 16, 2018 Report Posted February 16, 2018 Fred, If you are looking for a source of the circuit breaker, might I suggest... http://www.aircraftspruce.com/catalog/elpages/pbcircuitbrkr.php?gclid=Cj0KCQiA_JTUBRD4ARIsAL7_VeVCnfj23hrf1rEF1aAXrLOirRUqo6_4fzIb9EqWuNVMWWDJ9kJlqjgaAhXwEALw_wcB Check the part number on the one you have against what AS has. You should be able to get an exact replacement. The old mechanical CBs have a tendency to wear out and not carry the full load after a few decades... typical failure of the landing light CB. Best regards, -a- Quote
Oscar Avalle Posted February 16, 2018 Report Posted February 16, 2018 10 hours ago, Marauder said: Based on what I am seeing on that new breaker panel, it looks like you have room for new avionics. What’s next? Sent from my iPad using Tapatalk Pro Not really. The space next to the breakers is actually where the Garmin 795 goes. Additionally, even if I wanted something new, I really don't know what... may be a should look into upgrading into a 201 take all the avionics out and transfer them to my new plane. 1 Quote
0TreeLemur Posted February 17, 2018 Author Report Posted February 17, 2018 Thanks everyone. Lots of good stuff. Quote
0TreeLemur Posted February 18, 2018 Author Report Posted February 18, 2018 On 2/15/2018 at 6:08 AM, tony said: When I upgraded my panel, I replaced all my breakers and saved my old ones in a box. If you post a part number and I have what you need, I'll send it to you. Thanks for the offer Tony- I appreciate your offer. But, I think I'll do what you did and replace the old ones. They are brittle. Quote
