1 hour ago, HRM said:
You have two paths to ground from the battery through your transistors that will contribute to parasitic battery drain. The good news is that the reverse saturation (leakage) current for a 2N2222 is going to be in nano amperes.
I never considered the possibility that current could flow from the collector to the emitter without power to the base. A little ignorance goes a long way.
38 minutes ago, thinwing said:
Hey why don't you print out a circuit and get rid of that perf board...nah just kidding
I figure I'm lucky to put together enough information (and trial and error) to get a system that really works well. Getting timers or timer circuits that delay shut off for 15 or 30 seconds is easy. One that delays for 10 to 12 minutes was a lot more difficult (at least for a non electronic guy).
