mtrebbe Posted February 23, 2011 Report Posted February 23, 2011 Does anyone have any input about the shock absorber on the nose landing gear of a vintage Mooney. Mine (a 1968 F) still has the shock on it. I was told a few days ago that Mooney recommended removing it due to the possibility of it breaking and jamming the landing gear.
Hank Posted February 23, 2011 Report Posted February 23, 2011 My C doesn't have one [1970], and my neighbor's 75 F doesn't either. I've read that Mooney recommended the removal, but don't recall why. Seems there was a discussion about it late last year on the Mooney Tech Board.
sellis Posted February 23, 2011 Report Posted February 23, 2011 The shock absorber was found to be in effective and was removed. Email me direct and I will send you the approval drawing to remove the shock absorber. sellis@mooney.com
N601RX Posted March 31, 2013 Report Posted March 31, 2013 Does anyone have the drawing Stacy mentioned above? I'm trying not to bother him if anyone has a copy they could share.
N601RX Posted April 1, 2013 Report Posted April 1, 2013 No one volunteered the drawing so I e-mailed Stacey and he replied in less than 3 minutes with the drawing. Hows that for service? I've attached it here for anyone who needs it. You also get to reclaim a little over 2 lbs on your W&B Shock Removal.pdf
N601RX Posted April 1, 2013 Report Posted April 1, 2013 Thanks, Mike. I'll have to review my records, but I'm pretty sure that my '78 J was originally equipped with one of these, but there is no reference in my W&B to it have been removed. If I can document as much I might be able to reclaim those 2 pounds of useful load with a W&B update. Many thanks, Jim Another often overlooked W&B item is the Bendix to Slick change out. It often happens at engine overhaul and is simply not thought about. That and the shock will give you about 5 lbs.
