I need help swinging my magnetic compass. I have a 1963 M20C and cannot get my vertical card compass within an expectable range.
Last year when my plane was down for annual, I demagnetized all for the exposed tubing. Still no luck. :(    Will a wet compass work any better?
Any help will be greatly appreciated :)
Thank you,
Jon
I had a compass problem.  Turned out to be the engine mount bolt that is used for a ground strap attachment.  It is the top bolt on the left side.  I took a hand held compass and watched it go nuts when I moved it toward the engine cowling.  At first I thought it was my battery.  Removed it, still compass acted up.  Finally pinpointed it to that bolt, took it out and demagnetized it and compass problems disappeared.  I guess that all those years of passing a direct current thru it must have magnetized it, but don't really know.  Best of luck!
