rbridges Posted October 2, 2010 Report Posted October 2, 2010 first post on this forum, and I need help. I just recently purchased a '66 mooney c model, and it is awesome. anyway, it has a garmin 430 and king kx155 radios. a king kma-24 audio panel along with a 4 spot intercom completes the setup. the volume in the headset is very low. It doesn't matter which radios or headsets I use, I can barely hear radio traffic. I've even tried using the jacks in the rear sets. On the other hand, the intercom works fine. It has a separate volume control, and I can blow my eardrums out with it. There is a speaker located in the roof panel, and it is also very loud. When I select it with the KMA24, I can adjust the volume to the point where it's screaming at you. I've played with comm1 and comm2 volumes on the panel, and I've maxed out the volumes on the radios, but it never gets very loud through the headsets. Does it sound like bad wiring or possible problem with the KMA-24? thanks in advance.
fantom Posted October 2, 2010 Report Posted October 2, 2010 Jim...isn't there an excellent avionics shop in Robins, GA? If I were home, I'd look it up.
MooneyMitch Posted October 2, 2010 Report Posted October 2, 2010 Based on my experiences, your low volume issue appears to be at a common point associated with the audio panel. If you have someone that could loan you there working panel, you could insert it in place of yours for a test. If the problem still exists, then you have some wiring problems. I would be happy to provide a wiring schematic/pin out for to you for your KMA-24 auido panel. I am traveling at this time, but back home Sunday and I will forward it to you then.
rbridges Posted October 2, 2010 Author Report Posted October 2, 2010 thanks for the responses. is it simply a pigtail connection in the back or a bunch of separate wires? I did a search and it appears to be relatively easy to remove. I just don't want to end up with a big ole' mess.
jkb458 Posted October 11, 2010 Report Posted October 11, 2010 Hey Robert, Call Nick Porcell at Lowe Aviation, (478) 788-3491 (Middle Georgia Regional). Excellent avionics shop and first-class people!!! I fly into PXE often (twice a month) and would love to see your Mooney!!! Best regards, Jeff
rbridges Posted October 11, 2010 Author Report Posted October 11, 2010 Quote: jkb458 Hey Robert, Call Nick Porcell at Lowe Aviation, (478) 788-3491 (Middle Georgia Regional). Excellent avionics shop and first-class people!!! I fly into PXE often (twice a month) and would love to see your Mooney!!! Best regards, Jeff Jeff, We've fiddled with it a bit, and we think it's the panel. Unfortunately, bench testing it costs nearly as much as a used one. I'm tempted to buy a used King panel and switch it. Anyway, give me a shout the next time you fly down to the metropolis of Perry, GA. I've got the mooney in an open T hangar until a closed hangar becomes available. Rob
rbridges Posted October 5, 2011 Author Report Posted October 5, 2011 Quote: jkb458 Hey Robert, Call Nick Porcell at Lowe Aviation, (478) 788-3491 (Middle Georgia Regional). Excellent avionics shop and first-class people!!! I fly into PXE often (twice a month) and would love to see your Mooney!!! Best regards, Jeff
Apollo Posted October 6, 2011 Report Posted October 6, 2011 Have you changed your headset from Stereo to Mono mode?
Skeith Posted November 14, 2019 Report Posted November 14, 2019 Robert - Not sure if you will see this since this post is 10 years old, but we are having the exact same issues with a kma-24h and kx155 - curious if you would mind sharing what the problem was if you wouldn't mind - Thank you,
carusoam Posted November 14, 2019 Report Posted November 14, 2019 Welcome aboard skeith. We can ask @rbridges to hang by... Or you can join a current discussion regarding chasing everything from antennas to radios and everything in between... Expect no two challenges to be the same... Best regards, -a-
tmo Posted November 14, 2019 Report Posted November 14, 2019 (edited) carusoam - do we have a record thread resurrection situation here? can't figure out the @carusoam - ha, got it! Edited November 14, 2019 by tmo 1
rbridges Posted November 14, 2019 Author Report Posted November 14, 2019 I thought I'd update this 4643 posts later. Just an FYI for anyone else that may come across this thread. It turned out to be a bad capacitor in the KMA24 itself. It was repaired without too much hassle and worked great until I sold it for my PMA450. 1 1
