MooneyBob Posted May 27, 2015 Report Posted May 27, 2015 I would love to learn how to find all the lubrication points and use proper lubrication, grease, oils. I am in. Sorry I couldn't make it last weekend.
orionflt Posted May 27, 2015 Author Report Posted May 27, 2015 Just realized that My daughter has to be in Ohio for the start of school that weekend... will keep you posted Brian
Guitarmaster Posted May 27, 2015 Report Posted May 27, 2015 Brian -- I did owner assisted annuals through a good portion of the 1990s. I would love to go through a refresher for the owner eligible maintenance items. I will need to go look for my safety wire tool. I know I left it around here somewhere. Sent from my iPad using Tapatalk You're supposed to safety wire stuff? 1
orionflt Posted May 27, 2015 Author Report Posted May 27, 2015 ok, it looks like I can do the 29th of august if that will work for others. Brian 1
Seth Posted May 27, 2015 Report Posted May 27, 2015 Both dates work for me as of now. I agree with Alan that a few aircraft should be serviced so others can see/do the work. The hands on approach is a nice add on after the presentation. -Seth
DXB Posted May 28, 2015 Report Posted May 28, 2015 I will be certainly be there for any of the August dates, though my plane may not, given that it's scheduled for it's panel redo in August.
