Aerodon Posted April 12, 2015 Report Posted April 12, 2015 I have a couple of excellent EDM800 instruments that would make easy upgrades from EDM700 with or without fuel flow. Use your existing harness and add one or more of the following: I can take older EDM700's in trade, and pricing starts at $300 plus the options and harness you require. 1) OAT 2) RPM 3) Manifold pressure With these 3 options installed, the EDM800 will calculate % power. Then add: 4) Oil Temp 5) Oil P 6) Carb T 7) TIT 8) Fuel flow This generally requires no panel changes (Save $$) and has all the data of the EDM830. I also have EDM730/830 upgrade packages, and complete EDM830 packages (April / Sun n Fun rebates apply. Regards, Don Quote
Conrad Posted April 12, 2015 Report Posted April 12, 2015 Color me interested, I have a 700 w/ oil temp (and a flaky #3 egt probe) and would love to have fuel flow and % power. Quote
Aerodon Posted April 13, 2015 Author Report Posted April 13, 2015 Color me interested, I have a 700 w/ oil temp (and a flaky #3 egt probe) and would love to have fuel flow and % power. Rad, send me an email to supercub180@gmail.com and I'll put together an upgrade package quote with a free used EGT probe for you to try. Don Quote
podair Posted April 14, 2015 Report Posted April 14, 2015 very interesting offer, I have an EDM 700 with fuel flow. Looking to add 1+2+3 and oil temp, maybe oil pressure too. Quote
davidnz Posted April 17, 2015 Report Posted April 17, 2015 just a PIREP------> Don did a great job for me on a Edm 900 package....Highly recommended.... Quote
dmevans Posted April 17, 2015 Report Posted April 17, 2015 Am I out of luck if I have an EI UBG-16 Quote
Aerodon Posted April 17, 2015 Author Report Posted April 17, 2015 Am I out of luck if I have an EI UBG-16 Yes, SOL unfortunately. The issue with upgrades is that the cost of the probes and harnesses add up to more than the cost of a whole kit. But if you can reuse your EGT & CHT harness and probes, you have most of the system. I know EI have some competing products, so you should contact them to see what upgrades are available. Regards, Don Quote
Immelman Posted April 17, 2015 Report Posted April 17, 2015 What kind of deal can you give to upgrade EDM-700 display to the new LCD display (EDM 730 I believe)? My plane has CHT/EGT/Fuel flow/OAT, and I'd like to add more probes down the line. Quote
MHemperly Posted April 18, 2015 Report Posted April 18, 2015 Do you have a unit with a full harness? I don't have an analyzer in the plane at all. Just single egt Quote
Aerodon Posted April 18, 2015 Author Report Posted April 18, 2015 Do you have a unit with a full harness? I don't have an analyzer in the plane at all. Just single egt Yes I do, just send me an email to supercub180@gmail.com Don Quote
