N9453V Posted January 11, 2015 Report Posted January 11, 2015 Flying at dusk from HYI (San Marcos) to SAT (San Antonio International) in a Mooney M-20 with ATC audio. For the best experience, turn audio and captions on. http://youtu.be/J6WKZ4xVL_4 4
RocketAviator Posted January 12, 2015 Report Posted January 12, 2015 Good job, good radio skills. What camera did u use?
fantom Posted January 12, 2015 Report Posted January 12, 2015 That 12R SAT is an approach I've flown 50 times. Never gets old. Thanks for for the memories, and nice job! 1
ArtVandelay Posted January 12, 2015 Report Posted January 12, 2015 Good video. There is some debate on the read back of altimeter setting is necessary, i usually ignore it unless it's substantially different than the previous setting, am I the only one?
N9453V Posted January 12, 2015 Author Report Posted January 12, 2015 Good video. There is some debate on the read back of altimeter setting is necessary, i usually ignore it unless it's substantially different than the previous setting, am I the only one? Thanks, you're correct that it's not mandatory to read back the altimeter setting, however, the AIM recommends reading back altitude assignments (which are predicated on having the correct altimeter setting) and numbers, so I always do in US airspace. Canada is different, however, they seem to discourage reading back anything more than clearances and hold short instructions. AIM 4-4-7. b. ATC Clearance/Instruction Readback. Pilots of airborne aircraft should read back those parts of ATC clearances and instructions containing altitude assignments, vectors, or runway assignments as a means of mutual verification. The read back of the “numbers" serves as a double check between pilots and controllers and reduces the kinds of communications errors that occur when a number is either “misheard" or is incorrect. -Andrew
carusoam Posted January 12, 2015 Report Posted January 12, 2015 Thank you for sharing! Best regards, -a-
RocketAviator Posted January 12, 2015 Report Posted January 12, 2015 Thank you for sharing! Best regards, -a- Hey A, I hear u been out punching holes in the sky! Keep on eye on Ol Byron I here he gets a wee bit wild when away from home! Have fun fly safe! 1
