I made some new pieces for my F model out of flat aluminum stock using the old ones as a pattern.  You will need some basic sheet metal tools and time.  The round parts that go under the cylinders can be formed by hand using a large piece of pvc pipe. The materials cost around $25.  I cut them out with a scroll saw and then used a tabletop mounted belt/drum sander to smooth  up the cuts.  For some of the pieces you will need a small break.
