The-sky-captain Posted September 29, 2013 Report Posted September 29, 2013 I've got a small area ,about 2" x 3", on my rear side glass that got heavily scratched today after landing and unloading. Are there any scratch removal products that any of you MS members have used with good results? Quote
Rwsavory Posted September 29, 2013 Report Posted September 29, 2013 Micromesh. Here is a good instructional video on the topic: http://www.eaavideo.org/video.aspx?v=2616988646001 1 Quote
Nathan Peterson Posted September 30, 2013 Report Posted September 30, 2013 On 9/29/2013 at 11:07 PM, Rwsavory said: Micromesh. Here is a good instructional video on the topic: http://www.eaavideo.org/video.aspx?v=2616988646001 Thank you Sir! Nate Quote
The-sky-captain Posted September 30, 2013 Author Report Posted September 30, 2013 Looks easy enough, thanks for the lead. Quote
orionflt Posted September 30, 2013 Report Posted September 30, 2013 Be carful using the micro mesh and follow the instructions closely, it does a great job fixing scratches but you can really mess up your window if you do not use it correctly. I defiantly recommend watching the how to video before you attempt the repair. Quote
fantom Posted September 30, 2013 Report Posted September 30, 2013 On 9/30/2013 at 1:23 PM, orionflt said: Be carful using the micro mesh and follow the instructions closely, it does a great job fixing scratches but you can really mess up your window if you do not use it correctly. I defiantly recommend watching the how to video before you attempt the repair. Mega ditto! Quote
