Twing207 Posted April 26 Report Posted April 26 Hello all, I'm new to Mooney Space but I've learned a ton here - thank you for all the great info! I'm the builder/owner of a Long Ez and I recently bought a '66 M20C. I wanted a better solution for the Yoke mounted PTT switch. I don't like the velcro strap variation we've all seen and my airplane still has the vacuum PC system so replacing the PC disconnect valve wasn't an option. I had a spare yoke / control wheel and I 3D scanned it, then modeled a switch mount around the top of the yoke. The mount is an interference fit and snaps onto the yoke. Below are pictures of the installation, I'll share more once its installed in the airplane. Its meant to work with 6mm momentary switches available from various sources, but I used these ones here: https://www.mcmaster.com/catalog/131/1104/7400K111 The files could be modified for any switch or expanded if additional switches are needed. Attached is an STL file. - Disclaimer: check with applicable regs and your A&P before using. I recommend using a plastic that isn’t biodegradable. PTT-Yoke-66M20C.stl 5 2 Quote
1967 427 Posted April 26 Report Posted April 26 Awesome, now I have a reason to buy a 3D printer! ! 1 Quote
Echo Posted April 27 Report Posted April 27 I moved vacuum dump to panel and installed mine in the hole for the vacuum. Like it there and also prefer the PC on/off on panel instead of holding down button. 2 Quote
BDPetersen Posted Sunday at 11:11 AM Report Posted Sunday at 11:11 AM Introducing tewing207; the new owner of my under utilized “C”. Should be interesting for all. (He says I can still fly it.) 1 Quote
dkkim73 Posted Sunday at 11:38 AM Report Posted Sunday at 11:38 AM I think it's even cooler he built a Long EZ. I was seriously planning to build a Cozy back in the 2000's. 1 Quote
Twing207 Posted Sunday at 11:46 AM Author Report Posted Sunday at 11:46 AM 9 minutes ago, dkkim73 said: I think it's even cooler he built a Long EZ. I was seriously planning to build a Cozy back in the 2000's. They are also great airplanes, but there’s more room in a Mooney! Pictured here; my Long Ez (finished in early 2021), and my wife and I at Burt Rutan’s home in ID that same summer. We’ve been all over the country in it, but my family has out grown it with the addition of our daughter 3 Quote
dkkim73 Posted Sunday at 12:06 PM Report Posted Sunday at 12:06 PM *Great* pictures! It looks really clean and somewhat fighter like with the wing tanks. Very cool also you met The Great Man. I've heard him speak at Oshkosh years ago but never met him. I wonder how his new project (the ski amphib) is going. Thanks for sharing! 1 Quote
jamesm Posted Sunday at 11:34 PM Report Posted Sunday at 11:34 PM (edited) is it held on by tension? here is my cheap attempt to do a similar thing less creative by using aluminum angle and a hose clamp. an older picture. Edited Sunday at 11:42 PM by jamesm 1 Quote
Raymond J1 Posted Monday at 07:55 AM Report Posted Monday at 07:55 AM (edited) J'ai monté sur le bossage central logeant la montre. Edited Monday at 08:03 AM by Raymond J1 Quote
Fly Boomer Posted Monday at 12:55 PM Report Posted Monday at 12:55 PM 4 hours ago, Raymond J1 said: J'ai monté sur le bossage central logeant la montre. Looks like a handy place. Clean looking modification. Quote
Twing207 Posted Monday at 01:39 PM Author Report Posted Monday at 01:39 PM 14 hours ago, jamesm said: is it held on by tension? here is my cheap attempt to do a similar thing less creative by using aluminum angle and a hose clamp. an older picture. Yes, it’s meant to just fit tight enough. It sorta ‘snaps’ over the yoke. 1 Quote
1967 427 Posted Tuesday at 09:49 PM Report Posted Tuesday at 09:49 PM What type of material did you use(PETG Filament)? Quote
Matthew P Posted Tuesday at 11:51 PM Report Posted Tuesday at 11:51 PM if the leveler doesn't work, use that location for the new PTT, just thumb operated as opposed to index finger Quote
jeremyc209 Posted Wednesday at 05:54 AM Report Posted Wednesday at 05:54 AM On 4/26/2025 at 6:46 PM, Echo said: I moved vacuum dump to panel and installed mine in the hole for the vacuum. Like it there and also prefer the PC on/off on panel instead of holding down button. What button did you use for this? Got a pic? Quote
Echo Posted Thursday at 07:06 PM Report Posted Thursday at 07:06 PM On 4/30/2025 at 12:54 AM, jeremyc209 said: What button did you use for this? Got a pic? Do you mean for push to talk? I bought a yoke with it installed. Vacuum dump is a push pull. I have another I would sell if interested. Scott Quote
Hank Posted Thursday at 09:02 PM Report Posted Thursday at 09:02 PM This is how my PTT is installed. No 3D printer needed, just a scrap of metal and a couple of screws. The right yoke is even easier, as there's no clock in the way, but I can't find a photo right now. Quote
jeremyc209 Posted yesterday at 01:26 AM Report Posted yesterday at 01:26 AM 6 hours ago, Echo said: Do you mean for push to talk? I bought a yoke with it installed. Vacuum dump is a push pull. I have another I would sell if interested. Scott Yeah I was just curious which button was used for PTT and what you used for the vacuum dump. I'm in the process of getting my PC system running again and considered the panel vac dump + yoke PTT replacement. Quote
