warrenehc Posted Monday at 04:31 PM Report Posted Monday at 04:31 PM Hello all, I just got my plane back from the avionics shop with G3X and G5 upgraded. When stopped on ramp the IAS shows 20kt while stopped on the ramp. I have seen treads on the internet about this but for some reason I cannot locate them. Any help would be greatly appreciated. Thank you. Quote
varlajo Posted Monday at 04:36 PM Report Posted Monday at 04:36 PM Likely static system blockage. Could be water, could be a bug.. Quote
warrenehc Posted Monday at 04:49 PM Author Report Posted Monday at 04:49 PM Ok thank you in flight thing seemed ok but on ramp at idel it showed 20k. Quote
Jake@BevanAviation Posted Monday at 06:39 PM Report Posted Monday at 06:39 PM We had this happen before. Turned out to be the GSU25 had a issue. Quote
warrenehc Posted Monday at 07:00 PM Author Report Posted Monday at 07:00 PM With engine off it shows 0 TAS, with the slightest wind around the pitot tube (blowing air near it) causes it to jump. So it seems like it’s prop wash getting over and manipulating the TAS on the ground stopped. Different from last Mooney with Dual G5’s. I didn’t have that happen. Quote
201Steve Posted Monday at 08:31 PM Report Posted Monday at 08:31 PM They probably left it outside after they got finished and water got inside your static port. Sometimes the drain valve underneath the tail will clear it, sometimes it’s not enough to drain out and you have to pull the battery panel and visually locate and disconnect the line to let water trickle out. Quote
PT20J Posted Wednesday at 02:29 AM Report Posted Wednesday at 02:29 AM If it's pitot/static related, it should affect both the G3X and G5. If it's moisture you could try pushing both pitot and static drains. Quote
DC_Brasil Posted Friday at 01:06 AM Report Posted Friday at 01:06 AM My M20J with a G3X and G5 has a similar albeit not identical behavior: with engine running but at idle it will show zero IAS. However, at runnup power it will register a prop wash at around 20-ish kts. After accelerating past 35kts I am confident de IAS is very well calibrated (I have crosschecked it ina zero wind day with GPS ground speed). Quote
