Jetpilot86 Posted April 12, 2025 Report Posted April 12, 2025 Anyone have any initial numbers before I go test fly?
Dammit Bill Posted April 12, 2025 Report Posted April 12, 2025 Can you expand on your question? Do you have an AOA system installed? An Alpha Systems Eagle is being installed in my Bravo now. It will require a test flight to calibrate it Sent from my iPhone using Tapatalk
Jetpilot86 Posted April 12, 2025 Author Report Posted April 12, 2025 (edited) Mine is a function of an AV-20S I just had installed. It asks for upper and lower AOA warning numbers and I figure someone has the angles here, until I can get out and do a full calibration. Mine was set for +15° for the upper, and that seems a bit high off the cuff. Edited April 12, 2025 by Jetpilot86
kortopates Posted April 12, 2025 Report Posted April 12, 2025 sounds reasonable, verify what Vx is, it’s 12 degrees in most.Sent from my iPhone using Tapatalk
Jetpilot86 Posted April 13, 2025 Author Report Posted April 13, 2025 2 hours ago, kortopates said: sounds reasonable, verify what Vx is, it’s 12 degrees in most. Sent from my iPhone using Tapatalk That was going to be my next guess. I saw around 7-8° at 90k in the initial climb after flap retraction.
