jonhop Posted January 6, 2025 Report Posted January 6, 2025 (edited) Hi gang, I'm requesting your expertise here in sourcing a part. I bent my door hold and I might need a replacement. If my research is correct, it is part 310118-503 HOLD OPEN ARM. A quick search at LASAR didn't show anything in stock, so I thought I'd try here and give them a call later. Any insight is much appreciated. Edited January 6, 2025 by jonhop
N201MKTurbo Posted January 6, 2025 Report Posted January 6, 2025 I would just straighten that one. And keep it lubed so it doesn’t happen again. 3
M20S Driver Posted January 6, 2025 Report Posted January 6, 2025 10 minutes ago, N201MKTurbo said: I would just straighten that one. And keep it lubed so it doesn’t happen again. Or if you want to spend some money look at this https://www.ebay.com/p/6048688848 1
Brian2034 Posted January 7, 2025 Report Posted January 7, 2025 Remove it and straighten it with a hammer on a flat plate, been there done that not an issue and a 10 minute fix. 1
jonhop Posted January 7, 2025 Author Report Posted January 7, 2025 (edited) 21 hours ago, N201MKTurbo said: I would just straighten that one. And keep it lubed so it doesn’t happen again. Funny thing... I had just put lubricant on and was going to cycle the door a few times to spread it. Edited January 7, 2025 by jonhop
N201MKTurbo Posted January 7, 2025 Report Posted January 7, 2025 1 hour ago, jonhop said: Funny thing... I had just put lubricant on and was going to cycle the door a few times to spread it. bummer. Missed it by that much.... Mine actually did that once. I was able to straighten it in place. It has been fine ever since.
00-Negative Posted January 7, 2025 Report Posted January 7, 2025 Careful buying used even from a reputable seller like BAS. That unique barrel-shaped bearing may be missing. I just did this a few weeks ago. Removed mine and installed a light weight strut which I read about on earlier threads. -David
Lax291 Posted January 8, 2025 Report Posted January 8, 2025 On 1/6/2025 at 6:25 PM, N201MKTurbo said: I would just straighten that one. And keep it lubed so it doesn’t happen again. What is the recommended lube, Tri-flow?
Rwsavory Posted January 8, 2025 Report Posted January 8, 2025 9 minutes ago, Lax291 said: What is the recommended lube, Tri-flow? Yes. 1
N201MKTurbo Posted January 8, 2025 Report Posted January 8, 2025 1 hour ago, Lax291 said: What is the recommended lube, Tri-flow? Tri-Flow is good, but anything is better than nothing. 1
PT20J Posted January 8, 2025 Report Posted January 8, 2025 57 minutes ago, Thedude said: Which triflow should be used? According to the M20J Service Manual, the proper lubricant for the hold open arm is MIL-L-3545 grease which is Aeroshell 5. 1 1
Lax291 Posted January 8, 2025 Report Posted January 8, 2025 6 hours ago, PT20J said: Lube the baggage hold open arm also! You were reading my mind. 1
