Scottknoll Posted May 23, 2024 Report Posted May 23, 2024 Looking for help identifying the washer on our gascolator. Airight 51250. It’s not detailed in the Ovation IPC, and lasar could not find it either. I know they have the gasket kit, but the washer isn’t called out in that. My IA would like to replace as a it’s a little worse for wear (wallowed out hole and dinged up), it’s a pretty thin washer. It is located between the nut that holds the gascolator on. I can’t seem to locate a contact for Airight either. Quote
PT20J Posted May 23, 2024 Report Posted May 23, 2024 I would just search for thin stainless flat washers and see if you can find one with the proper dimensions. 1 Quote
