RightrudderM20E Posted April 20 Report Share Posted April 20 Been flying for about 10 years , came across a nice Mooney I want to buy . I’m new to Mooneys Getting prebuy done . I understand the usual items to look for . landing pucks fuel tanks corrosion anything specific to the E model to look at ? thanks Quote Link to comment Share on other sites More sharing options...
rickseeman Posted April 21 Report Share Posted April 21 I don't know of anything "E" specific. E's are pretty simple and have a great engine. My first one was an F and I was happy with it. Hopefully your prebuy guy has some Mooney knowledge. Quote Link to comment Share on other sites More sharing options...
Utah20Gflyer Posted April 21 Report Share Posted April 21 You definitely want to take a close look at the landing gear rigging and any wear to those parts. In particular the steering horn on the nose landing gear. Make sure the nose gear trunion hasn’t been damaged by oversteering. Make sure to check times on the mags so you know how much time is remaining before needing to Iran them. I highly recommend doing a thorough test flight to shake out issue you won’t be able to find with the plane in a hanger. Quote Link to comment Share on other sites More sharing options...
M20F Posted April 21 Report Share Posted April 21 Cam/lifters and spar corrosion, everything else is relatively inexpensive to fix. Quote Link to comment Share on other sites More sharing options...
RightrudderM20E Posted April 22 Author Report Share Posted April 22 16 hours ago, Utah20Gflyer said: You definitely want to take a close look at the landing gear rigging and any wear to those parts. In particular the steering horn on the nose landing gear. Make sure the nose gear trunion hasn’t been damaged by oversteering. Make sure to check times on the mags so you know how much time is remaining before needing to Iran them. I highly recommend doing a thorough test flight to shake out issue you won’t be able to find with the plane in a hanger. Thanks for advice , I did request a flight so will see if insurance can allow it Quote Link to comment Share on other sites More sharing options...
RightrudderM20E Posted April 22 Author Report Share Posted April 22 16 hours ago, M20F said: Cam/lifters and spar corrosion, everything else is relatively inexpensive to fix. Engine had a recent Iran so should be good on that , will check for corrosion on spar .. thanks RR Quote Link to comment Share on other sites More sharing options...
Shadrach Posted April 22 Report Share Posted April 22 Make sure that SB M20-208 has been completed. I would not buy any Mooney without putting eyes on the steel cage. 1 Quote Link to comment Share on other sites More sharing options...
