On 2/10/2024 at 11:35 AM, corn_flake said:
Does any one knows the size of grease fitting on M20E's landing gear?
My IA and I broke the one all the way in the more recess area of the gear.  Now I'm on the hunt to find replacement.
Search eBay; zerk 6-40 unf
 Alemite #3018 6-40 UNF-2A  usual broken one
Edited by Kelpro999
24 minutes ago, N201MKTurbo said:
The part numbers specified in the parts manual are all available on line for little money. You might as well use the right parts.
The right parts often don’t fit anymore because they were fitted with larger fittings when the original snapped out.
8 minutes ago, CaptainRamius said:
LockNLube has a neat tool to extract the grease fittings and retap if necessary. Zerks on my M20C are not standard. 2 different sizes on NLG. Some 7/32" others seems to be 7mm. IDK how metric can be on a 65 American airplane.
https://locknlube.com/products/grease-fitting-multi-tool-small
Somebody may have tapped it with a metric tap if it got stripped out or something.
