201Steve Posted January 30, 2024 Report Posted January 30, 2024 I just posted this thread. This company would be great for stuff like this. Quote
RoundTwo Posted January 30, 2024 Report Posted January 30, 2024 16 hours ago, Shadrach said: What a bargain at $1530 each. That would be a reasonable price for four. If made in any quantity, I’d guess those are marked up about 1000% over gross. Why not just have some made localy out of mild steel? My local CNC guy has fabricated larger pieces for me with 90° bends and precise drilled bolt hole patterns for >$150. I betting you could have identical plates made for <$200 each.. I just saw this morning that HangaRatz has drawing files for hold down plates he’ll send you for free that you can find someone locally to jet or laser cut for you. (1:50 in the video) https://youtu.be/3Pmn13n62qE?si=c_L0bKDaPXw9duBu 1 Quote
RideOrFly Posted January 30, 2024 Author Report Posted January 30, 2024 On 1/29/2024 at 11:40 AM, 1980Mooney said: Old discussion on plugged drain holes in the ribs. See comments by Target driver page 8 Interesting he says is not a "plane downer" but in this case it could have been. On 1/29/2024 at 11:58 AM, PT20J said: The fluorosilicone o-rings probably last forever. But, since the small one on the shaft cannot be inspected without disassembly, I do the pressure test every year. All you need is about a 3' length of vinyl tubing that will fit tightly over the tank vent and a spray bottle of soapy water (I just use Fantastik spray cleaner) and blow into the hose with your mouth to slightly pressurize the tank while spraying the soapy water on the cap and watch for bubbles. The fluorosilicone rings are the ones I ordered, and they just got here today. Any rough idea what the diameter on the fuel tank vent is? Quote
RideOrFly Posted January 30, 2024 Author Report Posted January 30, 2024 On 1/29/2024 at 11:30 AM, 1980Mooney said: If they found 2 plugged drain holes there are probably more. Over the past 20 years whoever resealed/repaired the tanks was sloppy. Plane Care may have missed some. You need a Mooney expert that knows where all the drain holes are. It seems that the Mooney expert is the hardest part to source at this point. The SB looks pretty comprehensive though, not much left to the imagination it appears. Quote
PT20J Posted January 30, 2024 Report Posted January 30, 2024 1 hour ago, RideOrFly said: Interesting he says is not a "plane downer" but in this case it could have been. The fluorosilicone rings are the ones I ordered, and they just got here today. Any rough idea what the diameter on the fuel tank vent is? 3/16" I think. 1 Quote
