Rick Junkin Posted May 8, 2023 Author Report Posted May 8, 2023 On 5/8/2023 at 1:18 PM, LANCECASPER said: Looks beautiful just the way it is! But since everyone else is going to be giving you suggestions to tweak it a little - here's my 2 cents. Expand Thanks for the inputs Lance. I had thought about moving the annunciator front and center and don’t recall why I left it in the original position. I’m gonna think on that again. (Just saw a post from Art that reminded me why I did this - I wanted to keep the G3X as high as possible) A benefit of some extra space at the bottom left of the panel is it will be a good place to put my iPhone mount. I fly from an uncontrolled field and am always fumbling with the phone when calling for my clearance. All the equipment is in hand now after a long order lead time wait so I’ll be staying with what I’ve got. A 275 would be nice, but I actually prefer the simplicity of the G5 as a backup. The 650xi vs 750xi was a conscious and considered decision based on the integration with the G3X and Foreflight and the idea that I’ll be using the G3X for as much data entry as possible. Also one of my objectives was easy access to all functions from the right seat, hence the comm panel and transponder. As for the TKS panel location, I harken back to a previous life of HOTAS ( hands on throttle and stick) convenience and put everything at my right hand that I expect to access in flight. My focus is function over aesthetics, but you’re right, it would look better centered. Cheers, Rick 1 Quote
Rick Junkin Posted May 8, 2023 Author Report Posted May 8, 2023 On 5/8/2023 at 2:28 PM, ArtVandelay said: Id figure out with the screen in split screen mode, where the PFD will be centered and center it on the yoke. I can’t imagine you’ll use full screen mode very often. Edit: I’d also install a panel mount compass and remove the factory hanging compass. Expand Good points Tom, and thanks for your input. I played around with the PFD positioning and decided I liked this arrangement best for my access and functionality desires for the G3X, G5 and WX-950. I’d have to move the G5 to the left side of the panel if I shifted the G3X to the right, and that would violate my “right hand access” rule. Ok, it’s more of a guideline than a rule. As for the compass, Hector at Aero Comfort just sent me a beautifully repaired and upholstered glare shield - with the original compass location. That’s it in the picture in the first post. That ship has sailed! Cheers, Rick Quote
Rick Junkin Posted May 8, 2023 Author Report Posted May 8, 2023 On 5/8/2023 at 1:18 PM, LANCECASPER said: Also since you are going all-Garmin I would spend a small amount extra and put the dedicated Smart-Glide switch on the panel. Expand Missed this the first time - the Smart Glide guarded switch is there, right above the throttle control and below the TOGA button. Cheers, Rick 1 Quote
rbp Posted May 9, 2023 Report Posted May 9, 2023 On 5/8/2023 at 1:18 PM, LANCECASPER said: Also since you are going all-Garmin I would spend a small amount extra and put the dedicated Smart-Glide switch on the panel. Expand hmmm, maybe on a panel with no Mode Controller? the 507 has LVL button with a blue border that activates smart glide if held for 3 seconds Quote
Pinecone Posted May 9, 2023 Report Posted May 9, 2023 Easy solution to the speed brakes issue. Switch to Electric Speed Brakes. I said EASY, not CHEAP. It was a huge Easter egg to find that this had been done to my plane, but not mentioned in the ad or conversations about the plane. 1 Quote
Rick Junkin Posted May 10, 2023 Author Report Posted May 10, 2023 On 5/9/2023 at 3:17 PM, rbp said: hmmm, maybe on a panel with no Mode Controller? the 507 has LVL button with a blue border that activates smart glide if held for 3 seconds Expand Acknowledged. Smart Glide can also be initiated through the 650xi. The beauty of the dedicated red guarded button is that when your reptile brain takes over in the moment your engine quits it only takes one push on the big red button to put everything in motion while you regain your wits and start focussed troubleshooting on the engine while George points you at the closest field and establishes best glide. Cheers, Rick Quote
ilovecornfields Posted May 10, 2023 Report Posted May 10, 2023 On 5/10/2023 at 3:38 AM, Rick Junkin said: Acknowledged. Smart Glide can also be initiated through the 650xi. The beauty of the dedicated red guarded button is that when your reptile brain takes over in the moment your engine quits it only takes one push on the big red button to put everything in motion while you regain your wits and start focussed troubleshooting on the engine while George points you at the closest field and establishes best glide. Cheers, Rick Expand What does it do if there’s no airport within gliding distance? Quote
Rick Junkin Posted May 10, 2023 Author Report Posted May 10, 2023 On 5/10/2023 at 3:50 AM, ilovecornfields said: What does it do if there’s no airport within gliding distance? Expand From the GTN xi manual: Smart Glide Function Functionality changes based on whether or not a suitable destination airport is within the estimated glide range. Suitable airport within glide range: • Configures Map to show pertinent glide information, including Smart Glide Range Ring and arrival AGL • Replaces existing flight plan with a direct glide route to a suitable destination airport • Provides a list of alternate airports that are within the estimated glide range • Indicates the best glide speed for the aircraft at gross weight • Triggers autopilot flight director modes to target configured best glide speed and follow the GPS Smart Glide direct-to route1 • Alerts pilot if glide destination falls outside the Smart Glide Range Ring • Allows direct tuning of emergency transponder code 77002 • Tunes standby COM to destination CTAF or tower frequency • CDI scale is set to 0.30 nm No suitable airport within glide range: • Configures Map to show pertinent glide information, including Smart Glide Range Ring • Indicates the best glide speed for the aircraft at gross weight • Triggers autopilot flight director modes to target configured best glide speed and level the wings1 • Allows direct tuning of emergency transponder code 77002 • Tunes standby COM to emergency frequency 121.5 • Provides altitude voice callouts for 2,000, 1,000, and 500 ft AGL 1 Requires a GFC 500/600 autopilot. 2 Requires a compatible transponder that can be controlled from GTN Xi. 1 Quote
rbp Posted May 10, 2023 Report Posted May 10, 2023 the G3X also has an emergency button the G3x also has an EMERG button in the 1 Quote
Rick Junkin Posted May 11, 2023 Author Report Posted May 11, 2023 On 5/10/2023 at 8:30 PM, rbp said: the G3X also has an emergency button Expand Also acknowledged. There are multiple ways to engage Smart Glide. The one that takes the fewest brain bites and least amount of time and systems knowledge is the big red button - lift the guard and push. The back story is I hadn’t planned to install either the 650xi or 750xi. I was going to go with a GNC 355 and GNC 255A and use the G3X as my primary interface for everything. I was reading about the Smart Glide capability and mentioned it in passing to my wife and she said “I want that!” Now, you need to understand that my wife is a reluctant flyer and has never asked for anything to be in the airplane. Further conversation with her around the “disabled pilot” scenario we had been practicing revealed she thought it would be an excellent idea to have a single button she could push that would fly the airplane to an airport with the engine out, and she wanted one. And she said it was well worth the cost difference between the 355 and the 650xi. So a single button it is, nice and big and red and different from any other switch on the panel so it’s easily identified and pushed. No buttonology knowledge or push-and-hold requirements. For that extremely unlikely event that both I and the engine fail at the same time. She’s happy. And we’re getting an awesome new panel. Cheers, Rick 3 Quote
rbp Posted May 11, 2023 Report Posted May 11, 2023 I’m not trying to deny you or your wife the button. or make any claims about ease of use or reptile brain. 1 Quote
Rick Junkin Posted June 2, 2023 Author Report Posted June 2, 2023 I updated the first post with a price list. Pictures of individual items are available on request. Cheers, Rick Quote
LANCECASPER Posted June 3, 2023 Report Posted June 3, 2023 On 5/10/2023 at 3:50 AM, ilovecornfields said: What does it do if there’s no airport within gliding distance? Expand The system plays a digitized version of "Taps" through the audio panel 1 2 Quote
Rick Junkin Posted June 3, 2023 Author Report Posted June 3, 2023 Turn coordinator, KX 165, and KN 64 SOLD. Quote
Rick Junkin Posted June 4, 2023 Author Report Posted June 4, 2023 EDM 830 (display only) adjusted to $1,200. I'll include as much of the harness and sensors as is salvageable/not reused but they haven't come out of the airplane yet. Quote
LANCECASPER Posted July 30, 2023 Report Posted July 30, 2023 On 7/30/2023 at 4:17 PM, LevelWing said: Is the altimeter still for sale? Expand If you want a reply, you'll want to quote him or ping him @Rick Junkin 1 1 Quote
LevelWing Posted July 30, 2023 Report Posted July 30, 2023 On 7/30/2023 at 6:49 PM, LANCECASPER said: If you want a reply, you'll want to quote him or ping him @Rick Junkin Expand Thanks. Quote
Rick Junkin Posted July 30, 2023 Author Report Posted July 30, 2023 On 7/30/2023 at 4:17 PM, LevelWing said: Is the altimeter still for sale? Expand @LevelWing Yes I still have the altimeter. I've sent you a PM. Cheers, Rick Quote
