Tavo Posted April 9, 2022 Report Posted April 9, 2022 What I learned for my next oil change. Don't pre-oil the tempest filter If I am removing the cowling by myself, next time use painter's tape to protect the cowling from scratching the body. Got a few scratches. Undo the vent house first Bring better music 3 1 Quote
carusoam Posted April 9, 2022 Report Posted April 9, 2022 Fantastic oil change for the O video! Thanks for sharing it. Best regards, -a- Quote
Fly Boomer Posted April 9, 2022 Report Posted April 9, 2022 @Tavo (or anyone else) why does everyone I know use quarts? I bought some gallons, but haven't used them yet. Maybe I'll figure it out when I do the next oil change. 1 Quote
amillet Posted April 9, 2022 Report Posted April 9, 2022 I never thought of adding the short hose to the quick drain. I wish the oil filter on my IO360 was as easy to change and safety wire. Quote
LANCECASPER Posted April 10, 2022 Report Posted April 10, 2022 Nice Video. The only thing I'd mention is that the Top #1 instruction printed on the Tempest EZ oil filter is not to put any lubrication on the gasket (the gasket has it built in). Tempest told me at Oshkosh the reason is that they have seen both extremes when people do that: (1) on some lower temp locations the oil or DC4 that people use combined with the lubricant built into the Tempest gasket doesn't seal and it develops leaks and (2) if it's in a very high temp application the two sealants combined cook, making it extremely difficult to get off, sometimes destroying the filter to get it off. I don't use any lube and have never had either issue. I much prefer the Tempest EZ filters to the old Tempest and the Champion filters. 2 Quote
Guest Posted June 7, 2022 Report Posted June 7, 2022 On 4/9/2022 at 2:53 PM, amillet said: I never thought of adding the short hose to the quick drain. I wish the oil filter on my IO360 was as easy to change and safety wire. I was told decades ago that the hose can cause the valve spout to vibrate against the body cutting the O ring and can cause leaks. Clarence Quote
