N201MKTurbo Posted November 13, 2024 Report Posted November 13, 2024 On 11/4/2024 at 5:44 PM, carusoam said: Sensata doesn’t sell direct to customers… because they suck… (plus they won’t sell just the printed switch caps) I use aircraft spruce… they may have them in stock, or can get from Sensata quite quickly… +1 for holding onto your existing switch caps… they snap on and off an oversized metal body… Landing lights of the original kind…(not LED) use a lot of electricity and generate a tiny spark each time you turn them on… this tiny spark knocks a micro piece of metal off the contact surface…. After years of operation, the CB switch loses its over center nature… the click gets softer and softer over time, as does its ability to resist tripping. PP thoughts only, not a mechanic… best regards, -a- You are mostly right about all this, but the contact points are separate from the disk that holds the switch in the on position. The current sensing element is a bimetallic domed disk with a small hole in the center of the dome. The switch rocker is spring loaded to the off position. When you turn the switch on, a small lever swings over the disk pushing it down which pushes the contact points together. This lever has a small bump on it that snaps into the hole in the dome holding the switch in the on position. The current flows through the dome. If the current gets too high, it causes the dome to flatten out which allows the spring loaded lever to snap back to the off position, this removes the downward force from the contact points allowing them to spring open. The switch wears out because of mechanical wear at the little hole in the dome and the bump on the lever. The hole wears bigger and the bump gets smaller and they don’t fit together very tightly after they are worn. The contact points are very beefy and usually have a lot of life left when the domes wear out. BTW, I have taken a few of these apart after they have worn out to see how they work and how they fail. 1 1
William A Posted November 13, 2024 Report Posted November 13, 2024 I am referring to the mounting holes not lining up with my current mounting holes not the switch itself. Perhaps I could use the original mounting sleeve to hold the new switch in place with some modifications.
jkarch Posted November 19, 2024 Report Posted November 19, 2024 So Air Mods changed out the rocker and put stickers on the switch rocker covers. Are these switches not available anymore?
William A Posted November 20, 2024 Report Posted November 20, 2024 Never used AirMods to order anything. What is the website?
carusoam Posted November 20, 2024 Report Posted November 20, 2024 15 hours ago, William A said: Never used AirMods to order anything. What is the website? https://www.airmodsflightcenter.com air mods is a classic Mooney Service Center… owned and operated by a guy that really knows Mooneys… probably not the place you would go for things that you can buy from the big box store… but, if you need it, and want it installed in a Mooney… great place to go in NJ. Best regards, -a- 1
carusoam Posted November 20, 2024 Report Posted November 20, 2024 19 hours ago, jkarch said: So Air Mods changed out the rocker and put stickers on the switch rocker covers. Are these switches not available anymore? The switch covers are hard to obtain… when you buy a switch, you get the choice of one cap… Sensata doesn’t make it easy to buy just the cap… we do have somebody around here 3D printing some pretty nice caps though… best regards, -a-
William A Posted November 20, 2024 Report Posted November 20, 2024 18 minutes ago, carusoam said: https://www.airmodsflightcenter.com air mods is a classic Mooney Service Center… owned and operated by a guy that really knows Mooneys… probably not the place you would go for things that you can buy from the big box store… but, if you need it, and want it installed in a Mooney… great place to go in NJ. Best regards, -a- sounds like the Don Maxwell of NJ! 1
carusoam Posted November 20, 2024 Report Posted November 20, 2024 17 minutes ago, William A said: sounds like the Don Maxwell of NJ! DMax did the PPI on my Ovation… Airmods did a few following annuals… best regards, -a- 1
