PT20J Posted December 8, 2023 Report Posted December 8, 2023 46 minutes ago, Kelpro999 said: Sometimes when tasks are repetitive the feeling of having done it are a little too fresh. I’ve done it more times than I’ll admit, I’m sorry it took your friend I cannot count the times I have returned to the hangar to check whether I turned off the light. 1 Quote
DonMuncy Posted December 8, 2023 Report Posted December 8, 2023 Sorry, I was not able to put in photos and words at the same time. 1 Quote
Pinecone Posted December 11, 2023 Report Posted December 11, 2023 On 12/8/2023 at 6:36 PM, DonMuncy said: HHHere That is pretty slick. Do you make and sell them? Do they work on later aircraft? Quote
DonMuncy Posted December 11, 2023 Report Posted December 11, 2023 I have only made the one set. The biggest problem is whether the "inside" horns of the yokes will accommodate the "posts". I assume the structural tube at the bottom of the panel is the same on all Mooneys. If you want to get a rough measurement of the diameter and depth of the cavity in the horns, and verify the bottom panel tube is semi-accessible, I will see if I could turn out another pair. We should be able to work out a reasonable price. Quote
