Hello everyone. I have a Narco MK12D radio that is having issues. My radio reception  is very poor and with low volume. I can hardly understand the ATIS even when 500 ft from the tower. The antenna was checked and found to be ok. I’m looking for recommendations on a good shop that could inspect the radio and repair as necessary. I realize that the Narco is a mediocre radio but I would like to keep it going until next summer when I plan to do a full panel upgrade. I’m in South Florida but don’t mind shipping it somewhere else if that improves the odds of getting it repaired correctly. Any help is greatly appreciated.
The D is the last version of radios Narco ever built...
It probably isn’t as bad as the other crud they built...
They closed up their shop right after the D came out... they didn’t succeed with a bridge to The digital (D) age...
You can throw money at it... because you are describing poor antenna connections...
Or buy a new radio and install a new antenna with new connections and ground plane....
Got a radio shop you like to work with?
If you want to see what else is available... there are pre-flown radios around here... including GTNs...
Expand
I’ve got a MK12D that has been more reliable than the brand G sitting above it.  They are actually quite good and robust.  Try these guys:  http://aircraftandavionics.com/
I had these guys work on my 12D+. I believe when Narco went belly up, they bought out a large portion of the service inventory.
Guys. Thank you for all the feedback. I have added the shops mentioned above to my list for future reference.  Also I found a shop in Arizona called Marks Avionics that also works on old Narco radios. I spoke with the owner and he told me that he has a very extensive inventory of parts for the Mark 12. Long story short my local avionics guy did some research and found out that some weldings in a particular board are known to cause the problem I was having. While he has no parts for my radio he asked me to allow him to take a look at it before sending it somewhere else. He did a detailed inspection and found a couple of weak welding connections in one of the boards. He cleaned them up and re soldered the affected ones. The radio is working great now so hopefully I won’t have any more issues for a while.
