shawnd Posted August 15, 2020 Report Posted August 15, 2020 Is there a way to bench test the strike finder on the ground? I imagine most folks don't run into lightning and thunderstorms and fly near it to see if its working. I have one installed as well and was thinking of pulling it along with ADF and Apollo GPS, but now I am second guessing. Quote
ArtVandelay Posted August 15, 2020 Report Posted August 15, 2020 Is there a way to bench test the strike finder on the ground? I imagine most folks don't run into lightning and thunderstorms and fly near it to see if its working. I have one installed as well and was thinking of pulling it along with ADF and Apollo GPS, but now I am second guessing. It should work up to 200 miles. AFAIK, it should work sitting on the ground, but maybe not in a hangar. 1 Quote
philiplane Posted August 15, 2020 Report Posted August 15, 2020 Mine wil detect lighting even in the hangar with doors closed. The orientation can be skewed due to all the metal, but it sees the lighting. You can do a basic function test with a corded electric drill. The more worn out, the better. Run the drill within a few feet of the antenna. 2 Quote
Tim Jodice Posted August 15, 2020 Report Posted August 15, 2020 1 minute ago, philiplane said: Mine wil detect lighting even in the hangar with doors closed. The orientation can be skewed due to all the metal, but it sees the lighting. You can do a basic function test with a corded electric drill. The more worn out, the better. Run the drill within a few feet of the antenna. It doesn't need to be corded but it needs to have a brushed motor to make the sparks. Quote
carusoam Posted August 16, 2020 Report Posted August 16, 2020 We have two types of lightning information... Strategic And Tactical... As IFR pilots we graduate from flying VFR and running into IMC to flying in IMC and running into thunderstorms.... Strategic... used for planning as you get closer... (data is delayed too long, time given is improper/not real... the data is old before it gets that assembly time stamp.) Adsb-in graphic weather data VM satellite graphic weather data Tactical.... avoidance when the chips are down... (real time) StrikeFinder Spherics type Onboard radar So if you fly IFR in IMC you are going to want to have one of each category... PP thoughts only, not a weather guy... Best regards, -a- 1 Quote
shawnd Posted August 16, 2020 Report Posted August 16, 2020 On 8/15/2020 at 2:59 PM, Tim Jodice said: It doesn't need to be corded but it needs to have a brushed motor to make the sparks. Nice - I will give this a shot to see if I can detect anything. If it needs to be replaced, I will be yanking this and putting in a newer computer that interfaces directly with the GTN-750. of course, later Quote
