OSUAV8TER Posted June 12, 2020 Report Posted June 12, 2020 If you're thinking upgrading your old Whelen or Grimes rotating beacon light consider the Whelen Aerospace Technologies (WAT) Orion 360 LED beacon lights. They come in all LED red or a split LED red/white with a couple different bases. For most Mooney applications (usually fuselage mounted) you will need the 3.75" base. These beacon lights are significantly smaller than the WAT 71080 series LED beacon lights and can use your existing wiring for fairly straight forward installations. They come with a 5 year warranty and are FAA PMA/STO/STC for Mooney aircraft. I have sold several to Mooney aircraft for mounting on the belly. For those mounting options, the beacons with the 3.75" base are needed. Orders over $500 ship free and there is no sales tax outside of Ohio.Model numbers:OR36R1W - All LED red beacon with a 3.75" base 14VOR36R2W - All LED red beacon with a 3.75" base 28VOR36S1W - Split LED red/white beacon with a 3.75" base 14VOR36S2W - Split LED red/white beacon with a 3.75" base 28VYou can order them off my website at http://www.gallagheraviationllc.com/whelen-aircraft-lighting.htmlPlease email me any questions or concerns you have at gallagheraviationllc@gmail.com
OSUAV8TER Posted June 22, 2020 Author Report Posted June 22, 2020 I have an excellent inventory and a wide selection of these LED beacon lights available for sale.If you're not sure what to get, email me at gallagheraviationllc@gmail.comhttp://www.gallagheraviationllc.com/whelen-aircraft-lighting.html <--- Order here!
OSUAV8TER Posted August 26, 2020 Author Report Posted August 26, 2020 I have plenty of these beautiful Orion 360 LED beacons in stock and ready to ship!
OSUAV8TER Posted April 16, 2021 Author Report Posted April 16, 2021 I have an excellent selection of 14V and 28V red or split red/white Orion 360 LED beacons in stock. For the belly beacon on Mooneys, you will need a beacon with a 3.75" base and a drain hole drilled through the top of the lens. Website - https://www.gallagheraviationllc.com/whelen-aircraft-lighting.html Email me - gallagheraviationllc@gmail.com Call me - 1-833-425-5288
OSUAV8TER Posted September 28, 2021 Author Report Posted September 28, 2021 I have all four of these beacons in stock in 14V and 28V. Mooneys with a belly beacon will need one with a 3.75" base. Pick your color, style, and correct voltage for proper install. It probably takes about an hour to install and they come with an STC or you might need to install it via a minor alteration. These beacons are FAA TSO approved as an anti-collision light system. Website - https://www.gallagheraviationllc.com/whelen-aircraft-lighting.html Email me - gallagheraviationllc@gmail.com Call me - 1-833-425-5288
OSUAV8TER Posted February 28, 2022 Author Report Posted February 28, 2022 I have an excellent inventory of all colors in 14V and 28V Orion 360 LED beacon lights. These are an excellent replacement choice for Mooneys with a belly beacon that is broken or you want to refresh. If you order today, it ships today. James
OSUAV8TER Posted May 9, 2022 Author Report Posted May 9, 2022 I just received more Orion 360 LED beacon lights in 14V and 28V. They are either all red or split red and white. I do have an all white Orion 360 only in 28V. If you're looking to replace your legacy beacon on the belly of your Mooney, the Orion 360 is an excellent option!
