4 hours ago, Parker_Woodruff said:
I was CFI onboard an M20R that experienced a transient propeller governor failure.  The engine rapidly accelerated to 3600+ RPM and held there until I could get the throttle pulled back.  Then it settled in at 2700 RPM.
By rapid acceleration, I mean basically instantaneous.  It was an MT.
I never want to hear that sound again.:ph34r:
I'm curious about the report where it says the pilot looked for max RPM on the ground and then adjusting the governor.  Can the M20J get to 2700 while standing still?  It can get close...not sure if it can get all the way there.
Here's a description from McCauley:
 Static Run-Up - What is Normal?
 There has been some confusion in the field concerning propeller low blade angle setting, the governor setting and how it relates to static run-up and take-off RPM. As a general rule, engine redline RPM cannot be reached during a full power static run-up. Contrary to popular belief, the governor is not controlling the propeller at this time, the propeller is against its low pitch stop. Attempting to increase propeller static run-up RPM by adjusting the governor high RPM screw will have no effect and will probably result in a propeller overspeed during the take-off roll. On a single engine aircraft several considerations determine both the low and high blade angle settings. Normally 25 to 100 RPM below rated take-off RPM is desirable and acceptable during a static run-up. McCauley's practice is to set the low blade angle so that rated take-off RPM is not reached until the aircraft has reached some significant groundspeed during roll out. At this time, and only this time, the propeller is controlled by the governor. There are two advantages to this practice. First, the maximum static RPM can be used as a check on developed horsepower as with a fixed pitch propeller. Any loss of maximum power over time is readily apparent during a preflight check. Second, if the propeller remains in a flat pitch after take-off due to some malfunction, the higher angle low pitch setting will permit more thrust to be developed to fly the aircraft without overspeeding the engine.
Exactly.  unless the governor was turned really low and they were able to increase static RPM at each adjustment, then I'm just scratching my head at this.
