Looks like a JPI EDM probe might be going funny on one of my cylinders (IO360 A1A M20F)
Quite sure now it is a probe issue but if anyone has another opinion:
WOT 65 to 75% power at 8-10k feet on two separate flights
leaned to peak
cyl 2 egt starts going haywire after 1h of flying
initially 10-20egt spikes then frequent 100 F spikes
engine humming smoothly chts rock steady and all 3 other egts too
LOP mag test smooth as well so ignition looks ok
even full rich egt 2 does not steady
flying 100-200 rop seem to calm things down for 10-15min spikes soon resume
same thing switching out of normalise mode calms things down then spikes again, up to 200-300f
50h check tuesday will swap probes and look and plugs too but at this point I m pretty sure its a duff probe now, i ve had huge spikes in egt without the engine missing a beat and everything else rock steady
also why does this stuff always happen when I m either over a mountain range or miles offshore?
It's a probe...maybe a loose connection.  Unless you have an STC'd blast furnace under the cowl, there's no way your CHTs are "spiking" 200-300df; if by "spiking" you mean 2 to 5 seconds. If you mean 2 to 5 minutes, well....
Loose, bad probe, or it's grounding out somewhere.
When I first bought my M20J, on my flight back to my home base, I had a loose grounding wire on the ship's instruments.  The net result was that the fuel quantity indicators were "windshield wiping" back and forth, the oil temp probe was slowly rising all the way up to the pegged position while the oil pressure gauge was falling all the way toward zero.  I pressed hard on the panel where the ships gauges are and the needles would all snap back to normal indications.  When it first happened, my heart initially dropped into my stomach.... then I pushed on the panel and realized it was just a loose wire.  Easy fix.... thankfully!
