Bryan Posted May 28, 2019 Report Posted May 28, 2019 Here is the latest update of my 252 Encore. I put the deposit on the equipment in late-late 2018 to take advantage of Garmin's holiday promotions. Because I have a factory 252 Encore, my vacuum was completely removed (primary and backup) for this upgrade as my speed brakes are electric and I am on the 28v electrical system with dual alternators. What I installed: G500 TXi, G5 backup, WX-500, EDM 930 to replace all my primary insturments, and CiES fuel senders. With the update, I was able to gain almost 50lbs by replacing the round gauges with glass - now up to 1110 #UL. I already had the GTN 750, FS 510, GMA 35c, and GTX 345. I'd still like to remove the KX155 with something more modern but that'll have to wait until next time. I had a big pause the first week of April when Garmin announced their G3X Certified. I was on the webinars and on the phone with my avionics shop for like two days, literally the week my bird was going down for install of the TXi. What I quickly realized, even though I could have changed over to the G3X, was that the G3X is limited to what can talk to it. My KFC 150 would not, my remote audio panel would not, and a couple of other things like a stormscope or radar. I priced a GFC 500 install but I had a hard-time replacing a perfectly working autopilot to save about 4AMU on the display with the labor about 14AMU just for KFC extraction and GFC install + equipment. I decided to stick with my TXi install and they even gave me a pretty big credit on the SVT enablement which brought the price much closer to the G3X. I had the panel made independently of the install shop and got to play around with the designs until I got what I wanted. They custom matched powder for my panel and laser eteched the plackards. It is a tight fit behind the panel but I love the design and layout. Super happy. I also went with the GCU 485 Dedicated PDF Controller. I fly a lot of IFR and don't want to be rolling a single knob in IMC in busy airspace on the TXi. So far the controller has proved very quick with changes to direct my KFC 150. The only thing that does not have a function is the IAS - right now it is just a bug on the TXi. I am hoping for a slide-in Aerocruze to be an option if/when my KFC 150 goes awry and should give me the IAS function. Right now, I think the KFC flies as good, if not better with the TXi controlling it. Altitude capture, VS, GPSS, HDG, Approach, ILS all works easier with one interface and no knob turning. A couple of not-seen additions were enabling the Telligence™ Voice Command that was apart of the remote audio panel. I thought this was a gimmic at best, but I use this in every phase of flight: "Tune to Clearance", "Tune to Weather" (ATIS or ASOS), "Tune to Ground", "Tune to Tower", "Tune to nearest Approach". It is very helpful. If there are multiple frequencies, it will show me on the 750 and let me select. The other thing that was enabled was the VNav guideance. This function is awesome. I don't get the benefit of my legacy KFC doing the actuall step-down VNav like the Garmin autopilots, but I hit two buttons to do that: VS-engage + ALT-arm and it will do the same thing. Automatically loading the crossing altitudes for STARs and or approaches is great situational awareness. I did not think this feature (built-into the GTN) was that big of a deal until it was enabled for the G500 displays. I am now having a fire-sale of all my existing equipment. Check that out here. 7
Jerry 5TJ Posted May 28, 2019 Report Posted May 28, 2019 (edited) Who makes that nice backup RPM/MP display? Edited May 28, 2019 by Jerry 5TJ
donkaye, MCFI Posted May 28, 2019 Report Posted May 28, 2019 Looks like a great setup. Why didn't the avionics shop bring over heading from the TXi magnetometer to the G5? Or did you set it up for TRK?
Bryan Posted May 28, 2019 Author Report Posted May 28, 2019 36 minutes ago, donkaye said: Looks like a great setup. Why didn't the avionics shop bring over heading from the TXi magnetometer to the G5? Or did you set it up for TRK? My G5 has a sync error for Heading and Baro they need to fix.
Bryan Posted May 28, 2019 Author Report Posted May 28, 2019 39 minutes ago, Jerry 5TJ said: Who makes that nice backup RPM/MP display? It comes with the EDM 930 and is required for all EDM 930 installations. 1
Davidv Posted May 29, 2019 Report Posted May 29, 2019 It looks amazing! At first I had some extreme jealousy as a bravo guy when it looked like you were getting 200+ TAS at 9.5 gph but it turns out it was 183 at 14.2. Now only mild jealousy :).
Bryan Posted May 29, 2019 Author Report Posted May 29, 2019 1 hour ago, Davidv said: It looks amazing! At first I had some extreme jealousy as a bravo guy when it looked like you were getting 200+ TAS at 9.5 gph but it turns out it was 183 at 14.2. Now only mild jealousy :). Yeah, I was playing with ROP, LOP settings in the new panel now that I have accurate TAS and primary engine monitor. Turns out that was one of my worse settings - I think that was 150° ROP at the top of ascent with my Cowl Flaps wide open. With accurate data, I am starting to record these settings for future use. Your Bravo will beat me at any altitude.
carusoam Posted May 29, 2019 Report Posted May 29, 2019 That is fantastic, Bryan! And the UL too. Nice pirep. thanks for sharing... Best regards, -a-
thomas1142 Posted May 29, 2019 Report Posted May 29, 2019 Very nice! Where did you get all the work done, and who cut the panel?
donkaye, MCFI Posted May 31, 2019 Report Posted May 31, 2019 Getting close. Detailed pictures of the installation here. https://drive.google.com/drive/folders/1-H0aJitqJ-2JV0T2arxWxXBTGfFdTH-6?usp=sharing Pictures below: 1. Before 2. After 1
Steve Skinner Posted May 31, 2019 Report Posted May 31, 2019 This looks terrific.I bet it flys like an Airline.Garmin should reimburse you for an all Garmin panel.(Except for the engine monitor)Congratulations DonSent from my iPad using Tapatalk
flyingcheesehead Posted May 31, 2019 Report Posted May 31, 2019 31 minutes ago, donkaye said: Pictures below: 1. Before 2. After Don, Your "two Befores ago" is better than most people's After. That's a great panel!
201Mooniac Posted May 31, 2019 Report Posted May 31, 2019 Don, the install looks great. Did the G5 fit in the same space as the ESI-500 or did you need a new panel cut?
donkaye, MCFI Posted May 31, 2019 Report Posted May 31, 2019 2 hours ago, 201Mooniac said: Don, the install looks great. Did the G5 fit in the same space as the ESI-500 or did you need a new panel cut? The G5 fit in the same place as the ESI 500 except the panel was modified by the shop to flush mount the G5.
Niko182 Posted June 5, 2019 Report Posted June 5, 2019 Don, Do you mind measuring the annunciator panel in the after picture and how much space it takes? Nik
donkaye, MCFI Posted July 22, 2019 Report Posted July 22, 2019 55 minutes ago, Niko182 said: is the KX nav hooked to the 500TXI? While I don't have any KXanythings, but you need the GAD 43E to interface such navigation equipment.
Niko182 Posted July 23, 2019 Report Posted July 23, 2019 18 hours ago, donkaye said: While I don't have any KXanythings, but you need the GAD 43E to interface such navigation equipment. this was meant for @Bryan. he has a KX155
