Thanks! Last question on the run-out, how much do you try to subtract for that? The entire cost of an overhaul? AOPA puts that at $22k...
The valuation tools noted above will let you enter hrs SMOH as part of the calculation.  Enter 2000 to value as runout.
Got it.
When I was looking most of the C's I saw either had no GPS or something really old.  The only ones I saw with 430's were hangar queens.  Might be worth a premium of the OP has his heart set on a 430.  Can't say much more without a closer look athlete airplane.  Looks nice in the pictures.
13 hours ago, Brandontwalker said:
APU port. Battery on C models is up front. Moved to the tail with the J.
An APU on a M20C?  That must be quite a mod!  Does it run off of JetA or 100LL?:P
  • 6 years later...
On 1/30/2018 at 5:42 PM, BKlott said:
Here is some info pertaining to 1968 Mooney Rangers (M20C):
Rangers and Mark 21s are almost the same aircraft, but are made in different years. Slight differences give the Mark 21 a slight edge in cruise speed. For instance, the Ranger doesn’t have a retractable step, movable cowl flaps or dorsal fin of the 21s. Also, the later Rangers didn’t have the flush riveted underwing. Though these are small items, they add up to 4-6 mph slower cruise speeds. Mark 21s from 1965 and later and all Rangers have 52-gallon fuel tanks, enough for almost a half-hour more cruise over the 48-gallon ’61-64 Mark 21s.
Mine is '64 Mark 21. It has 52 gallons
