Cris Posted August 30, 2017 Report Posted August 30, 2017 I am looking for the S-TEC drawings # 0599 & 05101 which are part of the 901 GPSS install instructions for the S-TEC 30. These drawings indicate what resistors need to be changed in the GPSS and roll computer to interface with an S-TEC 180 HSI. The current GPSS switch which I bought used is set up for a 52D54. I've searched high and low and can't find this info so I'm hopeful someone can assist. Thanks much
RLCarter Posted August 30, 2017 Report Posted August 30, 2017 will they email the drawings to you? http://genesys-aerosystems.com/
KSMooniac Posted August 30, 2017 Report Posted August 30, 2017 Good luck...they keep a tight lid on most of their data. You will likely need to go thru a dealer/shop.Sent from my LG-US996 using Tapatalk
N6758N Posted August 30, 2017 Report Posted August 30, 2017 2 hours ago, Cris said: I am looking for the S-TEC drawings # 0599 & 05101 which are part of the 901 GPSS install instructions for the S-TEC 30. These drawings indicate what resistors need to be changed in the GPSS and roll computer to interface with an S-TEC 180 HSI. The current GPSS switch which I bought used is set up for a 52D54. I've searched high and low and can't find this info so I'm hopeful someone can assist. Thanks much Hi Cris, Did you try @Alan Fox? Curious if you ever got the 55x installed, I am the one who sent you the tray for it... I still have access to some old avionics installation prints/manuals. I will look in the hangar next time I get a chance.
Cris Posted August 30, 2017 Author Report Posted August 30, 2017 Just sent you an e-mail Look forward to catching up.
przemekmac Posted December 11, 2020 Report Posted December 11, 2020 Hello guys, if someone have and could share st-901 mod drawing 0599 ? I need to connect it to gad29B (g5) heading source..
carusoam Posted December 12, 2020 Report Posted December 12, 2020 Welcome aboard prz. Unfortunately, the OP of this thread is unavailable... You might want to try one of the other names on the list... such as @Alan Fox Alan sells goods and services related to avionics... he may be helpful... Best regards, -a-
MoonFlyer68 Posted July 3, 2022 Report Posted July 3, 2022 I know this thread is a little bit old, but I have located the drawing 0599 and have attached it if anyone else needs them. 0599 SH1 REVG.pdf 0599 SH2 REVG.pdf 1
Dan C Posted June 2, 2023 Report Posted June 2, 2023 Thanks for the 0599 drawing ! Do you or anyone have the pinouts drawing for ST-901 ?
MoonFlyer68 Posted June 2, 2023 Report Posted June 2, 2023 2 hours ago, Dan C said: Thanks for the 0599 drawing ! Do you or anyone have the pinouts drawing for ST-901 ? I was able to purchase all the drawings for the ST-901 and used them to troubleshoot my autopilot. If you know the specific drawing number I can scan it for you. Or, what autopilot are you interfacing the 901 into and I will find the drawing that should apply.
Dan C Posted June 2, 2023 Report Posted June 2, 2023 I think I need drawing 10138 . The 901 is going between a Garmin GPS-400W and an S-Tec 50. Thanks for your help !!
Dan C Posted June 2, 2023 Report Posted June 2, 2023 hmmm, looks like Drawings 0594 and 99262 are also needed
MoonFlyer68 Posted June 2, 2023 Report Posted June 2, 2023 7 hours ago, Dan C said: hmmm, looks like Drawings 0594 and 99262 are also needed STEC 99262-L.pdfSTEC 10138-R.pdfSTEC 10138-L.pdfSTEC 0594-R.pdfSTEC 0594-L.pdfSTEC 99262-R.pdf Here are the drawings you requested. Due to the size of the drawings and limitations of the scanner, each one is two PDF's, a left and a right. I also tried to make sure that the fold cutoff was not at a critical area of the diagram. If you need any more drawings, I have all of them for the 901 interfacing to basically any STEC autopilot. I cost me $160 to get all the drawings on Ebay but they have been well worth it. When the shop installed my system I was able to figure out from the drawings that they left out a wire and that was causing the system to not work. 1 1
Dan C Posted June 2, 2023 Report Posted June 2, 2023 Wow - these are great - Thanks so much for your help !
Dan C Posted June 2, 2023 Report Posted June 2, 2023 Oh, it looks like you sent sheet 2 of 10138 (left and right). Could you please also send sheet 1 ? Thank you !
MoonFlyer68 Posted June 3, 2023 Report Posted June 3, 2023 9 hours ago, Dan C said: Oh, it looks like you sent sheet 2 of 10138 (left and right). Could you please also send sheet 1 ? Thank you ! Sorry about that. They were out of order, but still, I never turned the page. The missing pages. STEC 10138-1-L.pdfSTEC 10138-1-R.pdf
Beaglesfly Posted March 25, 2024 Report Posted March 25, 2024 Does anyone have a copy of drawing 05101? Trying to troubleshoot an st901 connected to a system 30.
Dan C Posted March 25, 2024 Report Posted March 25, 2024 Sorry Beaglesfly, I only have STEC 50 drawings. Good luck.
MoonFlyer68 Posted March 26, 2024 Report Posted March 26, 2024 19 hours ago, Beaglesfly said: Does anyone have a copy of drawing 05101? Trying to troubleshoot an st901 connected to a system 30. I should have that drawing at home. The only problem is I am overseas at work until mid June. If you haven't had any luck by then, I can hook you up.
drb930 Posted December 28, 2024 Report Posted December 28, 2024 On 6/2/2023 at 4:31 AM, MoonFlyer68 said: STEC 99262-L.pdf 541.87 kB · 18 downloads STEC 10138-R.pdf 266.95 kB · 13 downloads STEC 10138-L.pdf 296.11 kB · 17 downloads STEC 0594-R.pdf 392.07 kB · 14 downloads STEC 0594-L.pdf 391.24 kB · 15 downloads STEC 99262-R.pdf 612.54 kB · 16 downloads Here are the drawings you requested. Due to the size of the drawings and limitations of the scanner, each one is two PDF's, a left and a right. I also tried to make sure that the fold cutoff was not at a critical area of the diagram. If you need any more drawings, I have all of them for the 901 interfacing to basically any STEC autopilot. I cost me $160 to get all the drawings on Ebay but they have been well worth it. When the shop installed my system I was able to figure out from the drawings that they left out a wire and that was causing the system to not work. Would you happen to have access to S-Tec Drawings - S-Tec Installation Bulletin 684 Master Drawing List 92783 and 92784 Installation Bulletin ST-584 Installation Bulletin 187 Master Drawing List 9282 Installation Manual ST-084 Thanks, Dave
MoonFlyer68 Posted December 28, 2024 Report Posted December 28, 2024 3 hours ago, drb930 said: Would you happen to have access to S-Tec Drawings - S-Tec Installation Bulletin 684 Master Drawing List 92783 and 92784 Installation Bulletin ST-584 Installation Bulletin 187 Master Drawing List 9282 Installation Manual ST-084 Thanks, Dave Dave, I am currently out of the country but will be home middle of January. Once I am home I will see what I have. If I forget about it (always possible) just hit me up again.
drb930 Posted December 28, 2024 Report Posted December 28, 2024 7 hours ago, MoonFlyer68 said: Dave, I am currently out of the country but will be home middle of January. Once I am home I will see what I have. If I forget about it (always possible) just hit me up again. Thanks so much! Happy New Year and enjoy your trip.
MoonFlyer68 Posted January 20 Report Posted January 20 On 12/27/2024 at 11:28 PM, drb930 said: Would you happen to have access to S-Tec Drawings - S-Tec Installation Bulletin 684 Master Drawing List 92783 and 92784 Installation Bulletin ST-584 Installation Bulletin 187 Master Drawing List 9282 Installation Manual ST-084 Thanks, Dave Dave Unfortunately I am a no on all those documents. The stuff I have all seems to be about the ST-901 GPSS steering unit and how it interfaces with all the STEC AP units. Dan
