Home depot has tinted acrylic sheets.   Use the other side as a pattern.  The adel clamps that go on the fuel lines on top of the engine are about the right size if you need another clamp. Amazon also has tinted acrylic sheets
Thanks to the kindness and generosity and craftsmanship of one special MooneySpacer person.........problems solved.  I'm most gratefiul.   Thank you.
