thinwing Posted January 31, 2017 Report Posted January 31, 2017 28 minutes ago, LANCECASPER said: The cleanest install on a PS Engineering Audio Panel is to have them make the harness. http://www.ps-engineering.com/docs/PMA8000B_Harn.pdf Yeah..I get that but installs change!Add a device.. Quote
lifendet Posted April 23, 2018 Report Posted April 23, 2018 On 1/29/2017 at 4:12 PM, BigTex said: Looking at the configuration screen, it looks like it might be the fuel transducer might be acting up. Sent from my SAMSUNG-SM-G900A using Tapatalk Not to bring up an old thread but I'm having a similar pop up on my 530w since I bought the Aircraft. Not recieving input data on 232 channel #3. My question is how do I get to the config screen to see whats connected to 232 channel #3? Also Big Tex did you figure it out? Quote
bradp Posted April 23, 2018 Report Posted April 23, 2018 Power off and power on your unit holding the enter key down until the splash screen shows up.. the youbeill be able to see the config. Take a picture of each screen in case you mess something up. Quote
lifendet Posted April 27, 2018 Report Posted April 27, 2018 (edited) Took a snapshot of what I found. Saying shadin-fuel on channel 3. I do have a Fuel scan 450 hooked up but it works normal. Any ideas? Edited April 27, 2018 by lifendet Quote
N201MKTurbo Posted April 27, 2018 Report Posted April 27, 2018 3 hours ago, lifendet said: Took a snapshot of what I found. Saying shadin-fuel on channel 3. I do have a Fuel scan 450 hooked up but it works normal. Any ideas? Just because it works normal doesn't mean it is communicating with the Garmin. You need to check the wireing. Quote
