Hank Posted May 27, 2016 Report Posted May 27, 2016 . . . and this is why I leave painting to the professionals . . . Unless i can open a can and use a brush. Quote
bradp Posted May 27, 2016 Report Posted May 27, 2016 Wheel well is probably one of the mist important places to have covered with paint. There really important stuff down there relating to your spar and fuel tanks. A bunch of dirt gets thrown up by your tires and lands firmly in there. Dirt carries with it salts and moisture which is a setup for corrosion. Clean often with alcohol after you get it covered. Oh oh and please wear a respirator. All sorts of nasty organic chemical stuff wants to be in the same place as your head. Experience talking. Quote
1524J Posted May 28, 2016 Report Posted May 28, 2016 Google TO 1-1-8. Lots of good info concerning painting, corrosion prevention, ect. You might try 3M radial bristle discs for paint removal. Quote
pirate Posted May 28, 2016 Report Posted May 28, 2016 Did this for a living some time ago. I chemical stripped my airframe and gear with approved products 13 years back, still looks like the day I did it with NO ILL effects. Grease your gear and your flush interior / exterior panels throughly etc. Quote
1524J Posted May 28, 2016 Report Posted May 28, 2016 I would be a little nervous using avgas as a cleaner, especially sprayed. I use kerosene (jet fuel) as it has a higher flash point. Quote
1524J Posted May 28, 2016 Report Posted May 28, 2016 8 hours ago, Pirate said: Did this for a living some time ago. I chemical stripped my airframe and gear with approved products 13 years back, still looks like the day I did it with NO ILL effects. Grease your gear and your flush interior / exterior panels throughly etc. I did alot of research, made several phone calls about the discussion of stripping the polysulfude sealant from fuel tanks. Everyone I spoke with said that proper flushing, cleaning was the critical step even when using Polygone or SR125A. PPG now advertises SR125A as a paint stripper although they still have photos of a fuel tank on their website. Quote
