Jayhawk_aviator Posted March 20, 2016 Report Posted March 20, 2016 Reattaching the flywheel and spinner dome on the m20j. There is an "O" on the flywheel and crankshaft flange to line up, but I can't see the mark on the flange. I do see a 40 stamp on the edge of the flange, and it appears that that bushing is "stepped" at the point. Is that the O? Is there another way to find the O bushing? thnaks scott
wpbarnar Posted March 20, 2016 Report Posted March 20, 2016 I thought the "O" was stamped on the face of the fly wheel and face of the crank flange. If in doubt, couldn't you find TDC on compression for #1 cylinder and then verify the fly wheel is indexed correctly by looking at the timing marks on the fly wheel versus the dot on the starter or split line in the case? If indexed correctly the timing marks on the fly wheel should correspond correctly with the reference marks on the engine. Bill
Jayhawk_aviator Posted March 20, 2016 Author Report Posted March 20, 2016 That was my question I think. With #1 cylinder at tdc, should the tdc mark on the flywheel be lined with the arrow at the split in the case?
Guest Posted March 20, 2016 Report Posted March 20, 2016 The "O" on the starter ring gear support is meant to line up with the oversized crankshaft bushing. Clarence
Jayhawk_aviator Posted March 20, 2016 Author Report Posted March 20, 2016 Is the oversize bushing the one that has a "step" to it?
FloridaMan Posted March 26, 2016 Report Posted March 26, 2016 (edited) http://www.lycoming.com/Portals/0/techpublications/serviceinstructions/SI%201098H%20(03-08-2012)/Propeller%20Flange%20Bushing%20Location.pdf Next time, take a sharpie and put a mark on things before you take them apart Edited March 26, 2016 by Antares
Guest Posted March 26, 2016 Report Posted March 26, 2016 6 hours ago, Antares said: http://www.lycoming.com/Portals/0/techpublications/serviceinstructions/SI%201098H%20(03-08-2012)/Propeller%20Flange%20Bushing%20Location.pdf Next time, take a sharpie and put a mark on things before you take them apart That works provided the last guy put it on correctly. I've seen one where the was put on wrong and the hole was punched larger by the oversized bushing. Clarence
FloridaMan Posted March 26, 2016 Report Posted March 26, 2016 I've seen this too Sent from my iPhone using Tapatalk
