The starter contactor in your starter relay can build up a significant amount of carbon over the years, as well as erosion of the actual metal that transfers the current.
This could explain the voltage drop as well as the fact that it is hit or miss. Sometimes it makes good contact, sometimes it doesn't.
How old and rusty does your starter relay look?
If you occasionally have charging issues also, then your master relay becomes a possible factor for the same reason.
I did a little research and if you own a Sky-tec starter they can rebuild it for you for about half the cost of buying a new one. Definitely a good CB option and the guy at the factory said they replace anything and everything that needs replacing for a flat fee of $225 for my particular 149-12LS model. Standard turn around time is about 1 day. I'm copying and pasting their current rates for anyone who has a Sky-tec starter. He said your starter is as good as new and will come with an 8130.
Factory Rebuild
Program
  Rebuild-Exchange Program
for customers in a hurry
Model(s) Rebuild Price   Exchange Unit Charge Core Return Credit
NL (149-NL, 122-NL, 149-NLR) $255   $599 $344
NL/ec (149-NL/ec, 149-NLR/ec) $289   $679 $390
12V HT (149-12HT, 122-12HT) $289   $679 $391
24V HT
(149-24HT, 149-HT/ec, 122-24HT, 122-HT/ec)
$314   $739 $425
12V XLT (149-12XLT, 122-12XLT) $212   $499 $287
24V XLT (149-24XLT, 122-24XLT) $255   $599 $344
12V PM/LS (149-12LS, 149-12PM, 122-12LS, 122-12PM) $225   $529 $304
24V PM/LS (149-24LS, 149-24PM, 122-24PM) $267   $629 $362
12V LSA (149-LSA, 122-LSA) $267   $629 $362
ST2 (C12ST2, C12ST2/s) $346   $769 $423
C12ST1 n/a   n/a $329
C12ST3 $306   $679
$373
C24ST3 $324   $719 $395
C12ST4 $310   $689 $379
C24ST4 $333   $739 $406
C12ST5 $315   $699 $384
C24ST5 $342
Sky-tec customer care page
On 1/25/2016 at 6:16 PM, wishboneash said:
Thanks for your input N1395W. I will get to it one of these days when I can get away from work. After I get the cowling off, hopefully some quick clues.
Turned nothing was wrong. A&P started it without any problem. Intermittent? I don't know, will double check the connections before next time I fly.
  • 4 weeks later...
I finally got to do a run up today on the plane with a freshly rebuilt starter. The prop turned over fast and immediately . I have no doubt the 18 year old starter was the culprit for a slightly weak cranking speed before and the starting problem. In fact, looking back now I also think I changed out my 2 year old Concorde battery prematurely last year. Thanks for all the great advice from everyone.
Factory Rebuild
Program
24V HT
$314   $739 $425
C12ST1 n/a   n/a $329
C12ST3 $306   $679
$373
C24ST5 $342
What is an 8130?
