Does anyone know for sure, what the engine model or models were used on a 1957 MO-20A ? I am not sure if it was a Lycoming 0-320 or 0-360 ? This particular plane has a Hartzell constant speed prop HC-82VL-1D ............ does this prop have the recurring AD problems ??? Any reliable information is greatly appreciated !!!
Thanks, Mark
Best to check the type certificate on the FAA website to see what it should have.  It could have been changed in the last 59 years, though, via STC or field approval.
http://www.airweb.faa.gov/Regulatory_and_Guidance_library/rgMakeModel.nsf/0/60107bc8954c93a686256c24005b5075/$FILE/2A3.pdf
The M20 had an O-320, and the M20A had an O-360, but the TC date for the A is in 1958, so I wonder exactly which plane you're looking at...
It is a 1957 ....... Looks like the Lycoming 0-320 is correct ......... Aircraft been restored , work done on wings and engine , mechanic and owner passed away but no sign offs in the logbooks .......... Tons of paperwork and no missing logs
First there was an M20
Then there was an M20A
There are a handful of M20As around here...
really early Mooneys came with the 150hp engines.
Early 60's 180hp was standard.
Mid 60's 200hp became the new version of standard.
Today 310 hp....
Wooden planes take a fare amount of care above and beyond the metal and plastic ones.
Research how you are going to take care of this plane and what the related costs are going to be.  I would not expect the ordinary shops in the Mooney world would have the wood working skills that may be required.
Research the differences between the metal and wooden tail.
Somebody posted pictures of bare wooden wings recently.  They are a piece of flying art!
These are some ideas that come to mind.  I am not familiar with wooden planes.
Well,,,   Ill just put this here,,,  I would like to have it,,  If it was local, I would buy it...
Is this the 1 you have queries about?
1957 MOONEY M 20 • $8,000 • PROJECT FOR SALE  1957 M 20 mooney 3095ttaf, 0 320 lyc all new cylinders and cam, hartell prop model HC-82VL-1D o since inspected cad plated and balanced, all logs since new, wood wing has been rebuilt and recovered, new ignition harness, rebuilt mags & carb all paperwork. Plane has been in hanger since 1993. Does need to have some assembly done to finish I am not a mechanic This plane is being sold as is will sacrifice for this price. Many new parts I have over 15k invested no time to fix, do not call if not interested. • Contact Blane Robert - ROBERT'S AG AIR SERVICE, Owner - located LaMoure, ND USA • Telephone: 701-883-5047 • Fax: 701-883-4340 • Posted January 6, 2016  Show all Ads posted by this Advertiser  Recommend This Ad to a Friend  Email Advertiser  Save to Watchlist  Report This Ad  View Larger Pictures
scaled_130d_106x80_1092853-041_568d49d13 scaled_3102_106x80_1092853-042_568d4a11d scaled_927b_106x80_1092853-044_568d4a578 scaled_12e7_106x80_1092853-046_568d4ad65 scaled_a7e6_106x80_1092853-047_568d4b0f4
