Getting a major done due to bad cam lobe found at annual. Where to send oil cooler for flush ?  my A&P is not comfortable doing it.
Bill
3 hours ago, KSMooniac said:
Pacific Oil Cooler. Send your vernatherm too.
+1
we did that and they charged us 600$, which was 400$ more than quoted for the flush.  The receipt said "fin straightening" but that oil cooler looked the same, and since I took it off, I looked at it.  So get that straight before they go to the buffet with your credit card.
Bill, I paid $241 to POC to overhaul my oil cooler (8/2013). which included checking vernatherm. It also included some repairs. They were great to work with, fast turn around.
2 hours ago, tony said:
don't forget the prop governor too
Getting a new one of those... the original was declared "toast".
Thanks.
Bill
Thanks.. Bob.. I'm meeting with the A&P tomorrow.
Bill
I'll take pictures of it before we send it... Thanks for the warning.
Bill
1 minute ago, Wildhorsesracing said:
I put a PCU 5000 on mine and love it.
Jim,
That's what Triad said to replace it with... Thanks.
Bill
I installed a PCU 5000, it works great.The prop needs to be flushed also, it holds quite a bit of oil and sludge will build up in it over time. Although an A&P isn't allowed to do it, on a Hartzell its just a matter of screwing the dome off and replacing the O-rings when reassembling.
Also if your needing new oil cooler lines consider the Lasar oil cooler relocation kit.  It comes with new lines and gets the lines away from the exhaust.
I'm having my 3 blade prop serviced at the same time. thanks
Bill
