I have a question....
Why does Lycoming recommend starting the IO-360 with the mixture leaned when starting the engine cold? I understand for hot starts, but why on a cold start?
If the engine is COLD I perform the following:
1.) Mixture rich
2.) Electric Fuel Pump - Prime engine until fuel pressure peaks. Takes about 1 - 1.5 seconds
3.) Throttle - Crack 1/2"
4.) Crank Until Engine Start
5.) Lean aggressively
Some of the advantages I noticed...
-Engine fires up after 1-2 blades (Almost instantaneously)
-Engine seems to "Light off" a lot smoother
Can anyone provide any information as to why I shouldn't start the engine this way? I was thinking fouled plugs due to too much fuel in the cylinders, etc... I haven't seen any of these issues.
Also, I have tested this method at high elevation airports and various temperatures (50df - 100df). I have yet to run across a problem.
Thanks in advance.
-Derek
I don't know either, but I delivered an Arrow for a friend a few weeks ago and cut the mixture back to lean out of habit after priming and it would not start.  Then I caught myself doing it on the second attempt and left it full rich and it started right up.
1.) Mixture rich
When I start cold I use a 1/2" throttle and full rich, then turn on the fuel pump until the pressure comes up and count thousand 1 to 5 then turn off and pull full lean.  It always starts on the 1-2 blades.  The trick is to make sure you count to 5 after the fuel pressure is in the green.
  • 2 years later...
I tried this method today, and my lycoming io360 started in less that one blade!  But I think waiting too long to engage the starter after priming may cause flooding. I think I found my new method to start a cold lycoming!
1.) Mixture rich
Thanks in advance.
-Derek
