I recently purchased a 1992 Mooney M20J......  Beautiful aircraft!!!  I have looked for the paint "brand and codes" in the logs and the only information listed is Really White, Coral Red and Blue.  I'm certain the paint is a two part polyurethane but cannot fine the codes or cross match.  Can anyone provide some direction?
Thanks!
Rick
Paint has changed a lot over the years and even if you had the brand and codes the paint available today would not be the same and after 20+ yrs the original color would have weathered and faded. The easiest and best thing you can do is just have the paint color matched.
Brian
Thanks Brian.  Understand and agree.  But I would like to start with what was there to begin with.  There has got to be a Brand and Code for these colors.
Thanks!
Rick
According to my logbooks, in 1997 Really White was TP10010 in Pratt & Lambert.
This website may be helpful  http://www.aerotouchups.com/ . Their paint is expensive but the codes are there for many of the colors. They also have a pdf of some color charts.
I have a 1992 M20J and colors in original Log says:
Top Color Really White, Color# WP696, MFG, Pratt and Lambert
Accent/Trim Stripe, Color, Gold, Color#, H8066U,MFG, Dupont
Bottom Wing, Mooney Claret, Color# 576-541, MFG, Pratt and Lambert
Releew:
My Mooney still has its original paint job.  When I was part owner of an Arrow it had a white over blue scheme like Lance Casper's shown in his avatar but with a set of silver stripes between them instead of gold.
I have always liked that paint scheme but when I see yours (from your avatar) I like the boldness of the red.  Probably easier to spot too if I end up off airport in Northern Canada.
So..... all this to ask if you can post a pic or two of the exterior of your new-to-you Mooney.  I want to start gathering comparison schemes.
