M20D6607U Posted February 27, 2014 Report Posted February 27, 2014 Does anyone here know who to call for repairs on this Moritz gauge strip for this M20R Ovation. The CHT is both digital and analog. The needle quit but the digital still works. Thanks in advance. Ron Quote
KSMooniac Posted February 27, 2014 Report Posted February 27, 2014 Try an MSC first, but prepare yourself for an upgrade... Sent from my ADR6425LVW using Tapatalk Quote
M20D6607U Posted February 27, 2014 Author Report Posted February 27, 2014 Thanks, Lasar said Radiant Power Corp in Florida will repair them. They are way backed up at this time. So I'm trying to find another source/option Quote
KSMooniac Posted February 27, 2014 Report Posted February 27, 2014 At some point it makes more economic sense to convert to a replacement/primary engine monitor and ditch the Moritz gauges, both for cost and downtime reasons. Quote
jetdriven Posted February 27, 2014 Report Posted February 27, 2014 All those senders are a grand each. The Ovation we take care of had the oil temp gauge go bad. IIRC it was 3500$ for a flat-rate "overhaul" of the thing. Quote
Cris Posted February 28, 2014 Report Posted February 28, 2014 Several years ago I sent my Moritz gauge pkg with the fuel gauge & amps/volts back to Moritz Aerospace Inc for repair of the amp /volts. It was about $400 or so but I understand the aerospace assets were sold to a Fl. Company last year which I believe is Radiant Power Company. Give Moritz a call to see what they might suggest. I do know they indicated they were short on certain parts but were able to repair mine and replaced the light bulbs at the same time. Moritz Aerospace Corporation 2321 Topaz Drive Hatfield, PA 19440 Phone: (215) 996-9211 Web: Moritzaero.com Quote
M20D6607U Posted February 28, 2014 Author Report Posted February 28, 2014 Thank-you for the suggestions! I called the Moritz phone number and it has been disconnected. I sent it to Radiant Power Group for an evaluation hopefully it repairable. Ron Quote
harrispa Posted February 28, 2014 Report Posted February 28, 2014 My Moritz egt is erratic. Has anyone had success in trouble shooting/ fixing this problem? Paul Quote
Cris Posted February 28, 2014 Report Posted February 28, 2014 On 2/28/2014 at 11:59 AM, harrispa said: My Moritz egt is erratic. Has anyone had success in trouble shooting/ fixing this problem? Paul Paul I'd check the factory probe 1st. located on the exhaust tube. Those things have a limited life so it may be bad. In addition if you have an engine monitor or add one like the Insight G2 it legally replaces the Moritz gauge for EGT/CHT. Any repair to the gauge is going to be expensive as there is nothing you can do. Quote
Greg_D Posted February 28, 2014 Report Posted February 28, 2014 Are all of the Mooneys the factory is currently pruducing using G1000s? Do they even offer a steam guage option? If so, what are they using? I love the way those Moritz gauges look, but after seeing the repair costs, I'm glad I have the old style. Quote
harrispa Posted February 28, 2014 Report Posted February 28, 2014 Cris, thanks for the reply. I have a JPI, but would like the factory guage to work. I tried a JPI probe, but it didn't help. The probe I took out was an Alcor, do you know if this is the right factory probe? Paul Quote
Cris Posted March 1, 2014 Report Posted March 1, 2014 Sorry Paul I am not sure if that is the correct part but I would think a quick call to a MSC or even to a parts supplier with a cross reference might work. Quote
Cruiser Posted March 2, 2014 Report Posted March 2, 2014 the Parts catalog lists the EGT probe as an Alcor (NI) 86255 or Norwich (NI) 101-00204 Quote
harrispa Posted March 2, 2014 Report Posted March 2, 2014 Thanks, now I have verified the probe I need. Paul Quote
