Folks, I,m in Canada and no parts available here, I have shipping address in Massena N.Y.   complete or parts would be great,  also my rite bellcrank is bent and a new one required.   Thanks   Mike.
Ah, there are lots of bellcranks!   :)   In my J manual I don't see one, though, but there is a triangular welded part called a "Truss Assy" with part number 520006-501/-502 that I believe might be the part you're after.  I have no idea if it would be backwards compatible, though.  Perhaps John's E part will have the same number.
the truss  assy   is what I amlooking for, rite side,  could you check it with the above measurments I supplied, and if it is the same ,  how much?   thanks Mike.
Mike, I'll make an attempt to do so on Saturday or Sunday when I go back to the hangar as it is still installed in the wing.  It is supposed to be pretty cold here, though, and I may not be able to get it out if I can't stand being in the hangar for more than a short while, but I'll give it a try.
