I have a pair of panels from an Ovation that can be altered to fit into other air frames. They are the panels that make most of the roof and have the pillars that go around the windows. I had a second set which I altered to fit into my F model.
They can be the start of a very nice interior. They are fiberglass and easily remodeled. You can call me at (617) 877-0025 or e-mail me at johnabreda@yahoo.com
Thanks,
John Breda
Here are pictures of the parts. The first and third pictures show the parts covered in Eurostretch cloth. The middle picture shows the left hand panel which is available in the background, and a similar panel which I have altered to fit my aircraft in the foreground. You can cut and paste fiberglass parts so the contours are where you want them. You can also easily lay-up fiberglass and and to make the shape you want.
I can get some better pictures of the next 2-3 days.
John Breda
post-8543-0-89374400-1355870395_thumb.jp
post-8543-0-67560800-1355870420_thumb.jp
post-8543-0-41172000-1355870650_thumb.jp
Hi John,
I'm just in the minst of redoing my interior shortly. How hard was covering the panels with the Eurostretch material considering your skill set? I was told by Airtex it was difficult.
  • 2 weeks later...
It really is not difficult. You need to be clean and careful. Spraying on the glue is preferred. I used the same glue used by the factory. I do not have the name just now but can find it. John
  • 6 months later...
