Alan Maurer Posted Tuesday at 05:49 PM Report Posted Tuesday at 05:49 PM Hello Mooney People, New top overhaul has gone well and have now, after about 18 hours , gone back to AD oil instead of straight mineral oil. My question is..... When can I go back to adding Camguard to the oil. If the new cylinders will still break in a little , the Camguard would??? prevent that? Thanks Everyone! Alan
Alan Maurer Posted Tuesday at 05:50 PM Author Report Posted Tuesday at 05:50 PM Topic was supposed to be Camguard. Stupid computer changed that without asking permission!!!
Fritz1 Posted Tuesday at 06:01 PM Report Posted Tuesday at 06:01 PM If temps have come down break in is complete, cam guard to my best understanding is both, an anti scuffing agent and an anti corrosion agent, if you fly at least once a week you do not need the anti corrosion agent, gut feel I would give it one oil regular change interval, typically 25 or 50h depending on engine, before adding the camguard, others will chime in that know more 1 1
toto Posted Wednesday at 02:57 AM Report Posted Wednesday at 02:57 AM Yeah Camguard has both anti-corrosive and anti-wear. You can change your topic to Camguard in the little “…” menu …
Alan Maurer Posted Wednesday at 03:12 AM Author Report Posted Wednesday at 03:12 AM I did not know that
skykrawler Posted Wednesday at 01:09 PM Report Posted Wednesday at 01:09 PM If one is using oil with additive like Aeroshell W100 or Philips AW20W-50 adding Camguard is redundant. Some say use Camguard only with oil without the additive.
KSMooniac Posted Wednesday at 03:20 PM Report Posted Wednesday at 03:20 PM 2 hours ago, skykrawler said: If one is using oil with additive like Aeroshell W100 or Philips AW20W-50 adding Camguard is redundant. Some say use Camguard only with oil without the additive. Not correct... there is the Lycoming anti-scuff additive and that is different than the anti-corrosion package of Camguard. I run Phillips 20W-50 year-round with Camguard. I added Camguard after ~25 hours post-overhaul with my second oil change. 1
hammdo Posted Wednesday at 06:24 PM Report Posted Wednesday at 06:24 PM I’m doing X/C 20w50 and Phillips Anti-Rust (10%) in mine vs CamGuard right now. I can use Victory and Anti-Rust once I have about 100 hours on my engine… -Don
