I am looking for replacement static wicks. I ordered from Spruce and they came 6' long. The originals are 4" long.
Suggestions appreciated.
  • 1 month later...
Last time I looked for a replacement they were sold out.  I took the broken one and used epoxy and then put shrink wrap around it..still holding after 1 1/2 years!
Do they have electrical conductivity to the airframe? If not, they are just decorative.
Yes, The carbon core in mine are designed to allow electricity to control the rate of static charge dissipation.  If struck by lightning, they provide a path for the massive current to hopefully safety exit the aircrafts structure.
You said you repaired them with epoxy. Did you test them after you repaired them?
  • 3 weeks later...
I used the epoxy on the outer perimeter.  The epoxy can't be applied between the carbon fibers because the epoxy would act like an insulator and the wick would be considered useless.   I did this because at the time I could not find the exact replacement as suppliers were "out of stock"
On 12/7/2025 at 5:49 PM, N201MKTurbo said:
You can buy new ones from spruce for $35. They are not certified, but who would know or care.
The new style 4" rigid ones? I can't find them. Had to go through LASAR.
