billy hellcat Posted Wednesday at 08:52 PM Report Posted Wednesday at 08:52 PM Does anybody know who can service a turn coordinator for a Brittain autopilot? It’s a tc100 Evs. Tried porter strait in Tulsa and they don’t service them anymore. Thanks. Quote
N201MKTurbo Posted Wednesday at 09:02 PM Report Posted Wednesday at 09:02 PM http://www.berkshireinstrument.com/price_autopilot3.html https://www.kelleyinstruments.com/capabilities.html Quote
Igor_U Posted Wednesday at 09:46 PM Report Posted Wednesday at 09:46 PM Try contact Kevin Westbrook. He was working for Brittain for years and still helps people on the list. Good luck. @Kevin Westbrook 2 Quote
Bobaran Posted Thursday at 02:02 AM Report Posted Thursday at 02:02 AM Try contact Kevin Westbrook. He was working for Brittain for years and still helps people on the list. Good luck. [mention=48565]Kevin Westbrook[/mention]Yes, Kevin used to work for Brittain, building their turn coordinators. These are NOT diy fixit units, so get a professional to fix it. He can fix them but not provide a yellow tag.Sent from my SM-A526U using Tapatalk Quote
corn_flake Posted Thursday at 03:16 AM Report Posted Thursday at 03:16 AM Yeah, trust me. I tried to repair one my self. As soon as I realized I also had to build a rig to "turn" the coordinator 360 degree with exactly 2 minutes, I say, forget it!! I should let professional handle it. Keven did great work in bring it back alive!! Quote
N201MKTurbo Posted Thursday at 11:37 AM Report Posted Thursday at 11:37 AM You could build a rate table for about $100 on Amazon. Quote
Kevin Westbrook Posted Thursday at 02:57 PM Report Posted Thursday at 02:57 PM Billy Kevin Westbrook here call me 539-292-0474 2 Quote
corn_flake Posted Thursday at 07:27 PM Report Posted Thursday at 07:27 PM 7 hours ago, N201MKTurbo said: You could build a rate table for about $100 on Amazon. Interesting..... Searching or Rate table come up with nothing. Are you referring to buying parts for DIY rate table? Care the share a picture if you made one? Quote
N201MKTurbo Posted Thursday at 10:21 PM Report Posted Thursday at 10:21 PM I looked a bit, you can get 5 RPM 12V gear motor for $50. you will need to make some type of turntable and a 10/1 belt drive. I would get a lab power supply to fine tune the speed. You can calibrate it with a stopwatch. Or you can spend big bucks: https://www.ideal-aerosmith.com/products/1-2-or-3-axis-rate-and-positioning-tables/ Quote
cliffy Posted Thursday at 11:49 PM Report Posted Thursday at 11:49 PM 1 hour ago, N201MKTurbo said: I looked a bit, you can get 5 RPM 12V gear motor for $50. you will need to make some type of turntable and a 10/1 belt drive. I would get a lab power supply to fine tune the speed. You can calibrate it with a stopwatch. Or you can spend big bucks: https://www.ideal-aerosmith.com/products/1-2-or-3-axis-rate-and-positioning-tables/ Some of you here are way beyond the norm while the rest of us are still hammer, tong and forge! Quote
Rmfriday Posted Friday at 12:53 AM Report Posted Friday at 12:53 AM Call Kevin, he is great with all thing Brittain Quote
